Old 02-13-2013, 07:32 AM   #1
outdoors717's Avatar
2009 23' International
Milford , Michigan
Stabilizing jack 3/4 Drive Drill
I replaced my long manual hand crank with the Camco 57363 Leveling Scissor Jack Socket 3/4. My 12volt Ryobi just won't cut it when it comes to the torque and battery life required. I also don't want to run out of juice every time I have to raise and lower. Any suggestions from people currently using this setup would be of great help. I am looking for maybe a Dewalt etc... With battery life and torque for at least 8 up and downs of the stabilizing jack.
Mark
outdoors717 is offline   Reply With Quote
Old 02-13-2013, 07:46 AM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
I have an 18V DeWalt which works fine.
Bill
Mark
Just my personal opinion
Old 02-13-2013, 07:51 AM   #3
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We carry a small Milwaukee drill with spare battery; I think it would do the job but really is light effort to simply use the hand crank. I like the "feel" of setting them by hand so as not to over tighten.
An extra battery and charger is usually provided with the drills, which could be kept up with a small inverter when traveling between campsites.
doug k
Old 02-13-2013, 08:56 AM   #4
bganso's Avatar
1994 30' Excella
Truckee , California
Both batteries on my DeWalt gave out, so I bought an inexpensive Kawasaki from Costco for about $40 (a $30 savings over a single new DeWalt battery). It works great for raising/lowering the stabilizers. I've never run out of juice before recharging, but have probably only completed 4-5 up and downs before doing so.
bganso is offline   Reply With Quote
Old 02-13-2013, 09:19 AM   #5
Antique Pedaler's Avatar
2010 25' FB Flying Cloud
1964 17' Bambi II
Laramie , Wyoming
Images: 11
Been using a $20 Harbor freight drill for the leveler jacks and drilling out broken rivets. I must have lucked out as it's going on 3 years old and works fine.
Antique Pedaler
'64 Bambi II, '10 Flying Cloud FB
'05 GMC Pickup, 2018 Toyota Highlander
WBCCI # 4181 VAC member
Antique Pedaler is offline   Reply With Quote
Old 02-13-2013, 09:40 AM   #6
erock53's Avatar
1978 31' Sovereign
Cincinnati , Ohio
Maybe you should grease or oil the mechanism. The drill should only be lowering the jack so that it touches the ground and a little more. The jacks are not meant to "jack up" the trailer. I would think that I could raise and lower mine (50+) tiimes before the drill ran out of juice. I rebuilt my jacks and they move extremely easy. Almost no problem for the drill to move them.
http://e-rock53.blogspot.com/
TAC#: OH-13
erock53 is offline   Reply With Quote
Old 02-13-2013, 09:50 AM   #7
btowntincan's Avatar
Mercer Island , Washington
Erock has the answer. Grease the screws and it should work better.
btowntincan is offline   Reply With Quote
Old 02-13-2013, 10:10 AM   #8
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
We have been using a DeWalt 18 volt driver/drill to lower and raise Lucy's stabilizers for years. I wouldn't even think about using a hand crank. Lucy carries her own charger. We charge batteries while on shore power. We use the same batteries for Lucy's work light and her vacuum cleaner.
Brian
SuEllyn & Brian McCabe
Old 02-13-2013, 10:46 AM   #9
Wise Elder
Jammer's Avatar
2010 30' Classic
After using a battery-operated drill for a time I have gone back to using the hand crank most of the time. Using the drill doesn't make the job go materially faster and then there's the fuss with the battery and with making sure it doesn't get stolen. Nobody steals a crank.
Old 02-13-2013, 11:32 AM   #10
Central , Mississippi
I use a great big 1/2" Dewalt 3 speed. After trying 3-4 smaller drills I finally gave up and paid $150 for a big-dog.
From experience, I wont use grease on the screws again...1 trip down a dusty road and the grease grabbed so much dirt that even the crank would barely move them.
I've lubed with a spray on dry lube and I'm betting that rubbing a wax candle on the screw threads would work just as good.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 02-13-2013, 11:59 AM   #11
Don't forget your cat nap
Ag&Au's Avatar
Port Orchard , Washington
Mark
My first reaction is that the problem lies with something other than the drill.
Here are some ideas.
Drill's battery needs to be replaced.,
Stabilizer jacks need to be cleaned and lubricated.
More force than that needed for stabilization is being applied.
One or more jacks may have been deformed by too much force or impact from other objects.
Ken
Old 02-14-2013, 08:34 AM   #12
Milford , Michigan
Thanks everyone for the suggestions. I know the jacks are for stabilization only. They move just fine. I also have been using a dry lube that is wiped off pretty good. Yes they can accumulate plenty on dusty roads like the North Fork in Montana
I am rolling about 70 to 100 days a year. Was kind of looking for a speed up of the set up process in camp or just when stopping for one night and not un hooking. Maybe one could imagine a NASCAR pit crew. I think the battery is shot in the Ryobi, and the spare is headed in the same direction.
Outdoors717
Old 02-14-2013, 10:51 AM   #13
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
When we do an over night stop and leave the truck attached to the trailer, we do not bother with the levelers. One less thing to mess with in the morning.
Richard
Old 02-14-2013, 11:19 AM   #14
RLS
RLS's Avatar
2004 25' Classic
Prescott , Arizona
Same here, but I do put the tongue jack down a little to take the load off
Julia & Bob
W/ Deedee & Boo
AIR #30685
RLS is offline   Reply With Quote
