Old 01-21-2012, 06:44 PM   #1
Dunedin , Florida
Stabilizers
There is a single bolt at the end of the stabilizer. One of mine was missing so I removed one that was in place. Now I cannot get the new bolt to screw into anything and the one I removed does not screw to anything either. I thought it was the length so I bought longer bolts, still nothing. Anyone know what I need to do to replace the bolts? Thanks.
mshamilton is offline   Reply With Quote
Old 01-21-2012, 07:21 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
Given a little time I can come up with a photo of these screws. They are self-tapping ~1/4-5/16" screws. [exact diameter anyone?] They tap into steel channel of the frame. Therefore longer screws of the same diameter won't bite into the walls of the channel. You'll need to go up one in diameter to engage the channel. I'd try galvanized if I could find it.
A relevant thread on this matter - Stabilizer fell off
5 meter Langford Nahanni
Old 01-21-2012, 10:33 PM   #3
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, I had the same thing happen to my trailer. [vertually the same as yours] I had to drill, with a hole saw, 1" holes in the belly pan so I could slip some nuts in there for the bolt.
Bob 2005 Safari 25-B
YAMAHA 2400 / AIR #12144
Winter storage, taking the weight off the axles heavyjumbo Winterizing, Storage, Carports & Covers 47 10-24-2011 08:45 AM
HWH Leveller - where is the 15 amp fuse? Boom Sounds Mechanics Corner - Engines, Transmission & More... 3 09-22-2011 07:14 PM
Preparing to weather a Hurricane? FullTimin2HI Full-Timing 19 09-05-2011 05:19 PM
Electric stabilizers bike 2 eat Jacks, Stabilizers, Lifting and Leveling 1 04-14-2011 12:05 PM
Steering Stabilizers LaCajun Land Yacht/Legacy Motorhomes 2 01-15-2011 10:32 PM
