Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Jacks, Stabilizers, Lifting and Leveling
Old 02-13-2005, 12:38 PM   #1
Profile:  2000 27' Safari
Wappapello , Missouri
Question Stabilizer upgrade?
It's starting to remind me of my sailing days! When someone walks around in my trailer it feels like my old boat at anchor.
The stabilizers on my Safari are the lightweight variety and have some slop in them when you grab the support and wiggle it from side to side.
I saw a newer model Safari when camping in Fla. last week. It had stablizers with some additional bracing. Am wondering if this would be a worthwhile upgrade and would it be a reasonable project?
Bill Howell
Wappapello, Mo.
2000 Safari 27
2005 Dodge Ram 2500 Diesel
WBCCI #2526
wyhjr is offline   Reply With Quote
Old 02-13-2005, 07:04 PM   #2
Tarheel's Avatar
Profile:  2001 34' Limited S/O
Moyock , North Carolina
Images: 21
I have the electric stabalizers that came with the unit and I love them. I had a jamming problems with the unit and called the manufacture and he told me how to correct the problem and I have had none since then. www.ultra-fab.com looks like the product and the name Ultra Power Twin is the right name.
Keep the shiny side up.
WBCCI # 3485
Region 3 1stVP
Past President Tidewater Unit 111
visit tidewater Virginia's web page @
www.tidewaterwbcci.com
Rick Bell in "Silverbell"
Tarheel is offline   Reply With Quote
Old 02-13-2005, 09:10 PM   #3
jcanavera's Avatar
Profile:  2004 30' Classic Slideout
Fenton , Missouri
Images: 143
Airstream Registry
Originally Posted by wyhjr
\The stabilizers on my Safari are the lightweight variety and have some slop in them when you grab the support and wiggle it from side to side.
Bill, Airstream started using the heavier stabilizers for the Safari's beginning the 2002 model year. I had those light weight ones on my 2001. I had them upgraded up at Jackson center while visiting in the summer of 2001. It does make a big difference in the stability of your trailer. Apparently the mounting plates will cover the holes left by the old stabilizer units.
Jack
Jack Canavera
STL Mo.
AIR #56
'04 Classic 30' S.O.,'03 GMC Savana 2500,'08 Vespa GTS 250
Old 02-13-2005, 10:22 PM   #4
Profile:  2002 30' Classic S/O
Banning , California
Would a 2001 30' Classic w S/O have the light duty stabilizers or the "good ones"?
Chipster is offline   Reply With Quote
Old 02-14-2005, 07:06 AM   #5
jcanavera's Avatar
Fenton , Missouri
Images: 143
Airstream Registry
Chipster,
Only the Safari line had the light duty stabilizers prior to 2002. As a matter of fact the 1999 Safari line only had two rear stabilizers. None in the front. I ran into one of our forum members up at Jackson Center in 2001 who has having his two replaced with four of the good ones on this '99 27' Safari. He was the one who tipped me off about the upgrade and I subsequently had mine replaced while there.
You would know the difference since the light duty stabilizers didn't even have a built in pad on the leg. They were pretty much the equivalent of what I had on my Coleman pop up camper.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 02-14-2005, 08:53 AM   #6
Question
Thanks for the info, Jack. do you know if the job required removal of any belly panels? ( to gain access to the frame?)
Bill Howell
Wappapello, Mo.
2000 Safari 27
WBCCI #2526
Old 02-14-2005, 09:48 AM   #7
jcanavera's Avatar
Fenton , Missouri
Images: 143
Airstream Registry
Nope. They guys up at Jackson Center just removed the old stabilizers and drilled new holes. As noted earlier the mounting plate for the new jacks covered the holes from the old one. I think since the old ones were mounted to the frame outside the belly pan, it was a no brainer in mounting the new ones.
Jack
Jack Canavera
STL Mo.
AIR #56
Old 02-16-2005, 04:18 PM   #8
flyfisher's Avatar
Field and Stream , PA & MT
Rick -
I really like my electric stabilizes also, but have had jamming problems also when I retract them too far and the stabilizer pad wedges up into the upper plate that attaches to the trailer. Was that you problem as well, or something different? I'm interested in how your problem was fixed.
Incidentally, the ultra fabs are built for leveling your trailer (to some degree) as well as stabilizing, and they do work well as you've pointed out.
John
Flyfisher
flyfisher is offline   Reply With Quote
Old 02-16-2005, 04:34 PM   #9
jcanavera's Avatar
Fenton , Missouri
Images: 143
Airstream Registry
Originally Posted by flyfisher
Rick -
John
I haven't had the jamming problem on my stabilizers to this point.
Interesting on the Ultra Fabs, but I wouldn't put much stock in leveling function since I would assume this means that your frame can allow that kind of pressure on it. I've always assumed that with A/S you don't level with the stabilizer due to the stress put on the frame rather than an issue of the stabilizer itself.
Jack
Jack Canavera
STL Mo.
AIR #56
Steering Stabilizer rdm Mechanics Corner - Engines, Transmission & More... 2 09-17-2004 06:03 PM
Important upgrade - Cap Puller Janet Exterior Restoration Forum 9 04-18-2004 05:45 AM
steering stabilizer cooperhawk Mechanics Corner - Engines, Transmission & More... 3 07-17-2003 04:37 PM
disc brakes overlander Brakes & Brake Controllers 10 01-25-2003 11:29 PM
Temps in the Freezer/Frig??? tenrsingr Refrigerators 38 05-31-2002 03:34 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
