Old 09-15-2006, 12:50 PM   #1
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Stabilizer lubrication?
I was considering lubricating the threads of my stabilizers but was looking for anyone with experience with this. My concern is that I'll attract dirt and road grime. Silicone doesn't seem adequate, grease or antiseize would attract dirt, anyone with a "hot" product or idea? Should I leave them dry?
Fyrzowt is offline   Reply With Quote
Old 09-15-2006, 01:06 PM   #2
1 Rivet Short
1989 25' Excella
By The Bay , Rhode Island
I use a little motor oil in a squirt can...seems to work fine.
BillTex is offline   Reply With Quote
Old 09-15-2006, 01:07 PM   #3
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
2nd vote for motor oil.
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 09-15-2006, 01:13 PM   #4
Steve & Susan's Avatar
2005 28' International CCD
Willoughby , Ohio
I use spray-on white lithium grease, so far dirt is not a problem.
Steve & Susan
WBCCI# 03876
AIR# 6511
2005 28' CCD, 2011 Sierra 5.3L, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 09-15-2006, 02:25 PM   #5
McLogger's Avatar
Columbia , South Carolina
I apply white grease as well. Doesn't matter what you use it is going to be messy and get on stuff if you touch it or something brushes up against it. I have been told to leave it all dry?? I can't say I have seen a difference either way.
Happy Camping
McLogger, AIR # 16452
McLogger is offline   Reply With Quote
Old 09-15-2006, 02:58 PM   #6
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
Spray Gel-Lube
In the shop we have replaced the spray white grease with the more modern spray gel-lubes.
This is synthetic based, clear, high pressure and temperature penetrating grease. They go on fairly liquid but after a short period of time the solvent evaporates out leaving the lube where you want it.
The brand of choice is 3M 08878 spray lube, but there are other similar cans that show up from Worth, 1st Ayd ect.
Another choice is Tri-Flow which dries a little bit less greasy but stinks to high heaven. Not a good choice for window cranks. (Been there, done that.)
Check out your auto parts store and see what they have in stock.
Tom.
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
Old 09-15-2006, 06:32 PM   #7
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
I also like the white lithium grease.
SuEllyn & Brian McCabe
Old 09-15-2006, 08:46 PM   #8
lewster's Avatar
Naples, FL , Hood River, OR
DuPont Multi-Purpose Dry Lube
DuPont Multi-Purpose Dry Lube is the ONLY lube I use when dirt attraction is a possibility. I use it on bicycle and motorcycle chains and it never draws gritty dirt to it. It stays clean a very long time and is also waterproof.
Old 09-15-2006, 08:52 PM   #9
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Can you advise the price and how long it will take to ship. Trying to get our unit ready for winter. PM me if thats better.
Old 09-15-2006, 10:41 PM   #10
McLogger's Avatar
Where can you find it? I have seen dry lube before but not in a spray? Also what should it cost?
Old 09-16-2006, 04:26 AM   #11
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
i use white lithium grease in a spray can. or LPS 2.
a shot once a year works well.
john
you call them ferrets, i call them weasels.
Old 09-16-2006, 06:49 AM   #12
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
What about using grafite spray?
'77 Sovereign Intl 31' CB
Old 09-16-2006, 07:38 AM   #13
Images: 59
You can buy Rock 'N' Roll chain lube at most bicycle shops. Use the "hard road" grade for best results.
Old 09-16-2006, 04:56 PM   #14
lewster's Avatar
Most Lowe's have it....about $5 a can or google duPont Multit-Puyrpose Dry Lube. There are lots of places on the net that sell it.
steering stabilizer ALANSD Mechanics Corner - Engines, Transmission & More... 34 04-01-2014 09:48 AM
Steering Stabilizer rdm Mechanics Corner - Engines, Transmission & More... 2 09-17-2004 06:03 PM
Bal Stabilizer lubrication mandolindave Jacks, Stabilizers, Lifting and Leveling 4 02-19-2004 09:51 PM
steering stabilizer cooperhawk Mechanics Corner - Engines, Transmission & More... 3 07-17-2003 04:37 PM
Temps in the Freezer/Frig??? tenrsingr Refrigerators 38 05-31-2002 03:34 PM
