Old 11-11-2010, 06:18 AM   #15
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
my knees are creaking so loud that i cant hear anything. will spray with boeshild.
noreen&sal is offline   Reply With Quote
Old 11-11-2010, 07:01 AM   #16
_
lube choice DEPENDS on which model/brand of stab jacks are on the stream...
1. >>>the 'bal' light trailer stab' jacks (used on safari/i'nationals/clouds) require...
any light 'spray lube' on the exposed screws/threads, choose yer favorite and spray at will.
2. >>>the 'ultra-fab' electric leveling jacks (typically model UF-5000 power twin) have GREASE ZERKS...
and require any standard moly grease injected till it ooozes out the excess/exit port.
do NOT spray stuff externally onto the threads of the ultrafab, it will muckup the grease that's inside.
___________
the majority of low lying 'squEEEaks' noted INSIDE a stream are from the subfloor/frame attachment.
although all the external joints and metal stuff can squeak 2.
cheers
2air'
Old 11-11-2010, 07:32 AM   #17
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
I have found that chain lube for bicycles works well. It dries as a waxy lubricant and is designed for mountain bikes to resist sticking dirt.
mojo is offline   Reply With Quote
Replacement stabilizer jack mikeandbecky Jacks, Stabilizers, Lifting and Leveling 4 08-29-2007 05:39 AM
Stabilizer Jack Installation uwe Jacks, Stabilizers, Lifting and Leveling 16 11-11-2004 05:39 PM
Stabilizer jack stuck Tinsel Loaf Jacks, Stabilizers, Lifting and Leveling 10 03-12-2004 11:43 AM
