02-21-2016, 02:44 PM
2016 28' Flying Cloud
New Port Richey
Stabilizer deployment
Just got our 2016 28 Ft Flying Cloud, dealer in Tampa Fl suggested I get a battery powered impact driver to lower and raise the stabilizers. Any thoughts or suggestions about best way to handle this?
02-21-2016, 03:09 PM
1978 25' Tradewind
Metro Phoenix
And I'll bet the dealer has one he'd be glad to sell you for only $999.99. Then you have to worry about keeping it charged and all that hooey. Get a crank handle speed wrench instead:
"Between what matters and what seems to matter, how should the world we know judge wisely?" - E.C. Bentley, Trent's Last Case
02-21-2016, 03:17 PM
2016 25' Flying Cloud
Venice
I use a portable power drill. You can buy the attachment on line or at most hardware stores. Works great & just takes about one minute to lower or raise all stabilizers.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2018 Nissan Titan XD Cummins Diesel
02-21-2016, 03:25 PM
2012 25' Flying Cloud
Battle Lake
We use a quality compact power drill with lithium ion batteries. You can pick up the 3/4 inch socket to fit the drill at any camping store. We also use it to adjust our ProPride hitch weight distribution screw jacks, the snug them with a wrench. Easy peasy.
Doug and Cheryl
02-21-2016, 03:36 PM
1988 29' Excella
Plant City
The drill is the way to go I used a battery powered impact once it makes a lot of noise.
02-21-2016, 03:44 PM
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach
Definitely use a drill. An impact driver will wake up the dead. We use a DeWalt 12 volt. It is more than powerful enough the handle Lucy's stabilizers. It can also handler the weight distribution bars on the Hensley.
We used to use a DeWalt 18 volt. The 12 volt is half the weight and does as well.
Brian
SuEllyn & Brian McCabe
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
02-21-2016, 03:46 PM
2018 23' Flying Cloud
Huntsville
Using a drill for stabilizers. May want to use caution, not to firmly against the ground.
Ron
02-21-2016, 03:49 PM
1988 25' Excella
1987 32' Excella
Knoxville
I use a drill. The impact driver works better but is loud. I do not use the stabilizer all the time and never when we stay hooked up. Lithium ion drill is very handy as is the impact driver. I carry a kit that came with both and an extra battery.
02-21-2016, 04:01 PM
1999 34' Excella
Hillsboro
Drill it!!!!! You will need a 3/4" socket to fit the stabilizer Screw head. Camco makes one which fits well into drill chuck and stabilizer screw head. See here: https://www.amazon.com/gp/aw/d/B001V...mco+stabilizer
Take care about the drill that you don't over tighten the stabilizers...that is not good for your Airstream as it will cause does and other stuff to not fit well.
Also, when you have almost deployed or retracted the stabilizer, the sudden stop can cause injury to you and Airstream siding/trim, etc.
I have my drill torque set low enough that it won't likely be uncontrollable.
Peace and Blessings..
Channing
WBCCI# 30676
02-21-2016, 04:46 PM
2024 23' Flying Cloud
San Antonio
We use the crank handle that came with the Airstream. Never needs charging. Works every time. We just kneel on a work glove to save staining our evening wear. Contacts the ground, give it another 3/4 turn, or so. You will feel it.
Of course, we are kinda of nutty purists in certain respects. I still have two manual turntables and 1000+ vinyl albums in the stick-and-mortar.
Cannonball, Deep in the Heart of Texas!
WBCCI #4387, Air #84080
02-21-2016, 04:49 PM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
The cordless drill is definitely the way to go. Plus you'll have it on-board for other tasks. Not much other use for an impact driver in an RV.
Bob Martel
WBCCI# 5766
02-21-2016, 05:02 PM
1987 Avion 34W owner
Good Ol'
, USA
I like the crank handle best. I always know where it is..... It doesn't need charging, etc, etc.
Of course, I like my antique drill brace, too, for making holes in stuff. It's way older than I am!
PaulnGina
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
Blessed and highly favored
I this great country!!!!
1987 Avion 34W
02-21-2016, 06:30 PM
Free Range Human
2012 25' FB Flying Cloud
Haines
A drill works well, sometimes too well. Be careful to not over extend/retract the stabilizer. If you really jam it, it is a €%#& to free up. Don't ask how I know...
I'm quite fond of the speed handle these days.
02-21-2016, 06:39 PM
Walnut Creek
A drill would add weight and I'd have to carry the crank as a backup anyway. It's part of staying fit along with levering the sway control into position.
When I can't turn the hand crank, I'll get a drill. What ever it takes. Pat
02-21-2016, 06:41 PM
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction
Use the factory supplied speed wrench on the Classic. Have some ⅛" roll pin on hand to replace the turning handle keeper when it finally shears off. Got a ⅜" spinner wrench at Harbor Freight and a swivel ¾" shallow socket. I then use the Hensley supplied wrench to fine tune the left arms.
Tried the drill idea, but it's something else to keep charged. The battery tends to be low when I need to use it.....
02-21-2016, 06:59 PM
Brandenburg
, Kentucky
Drill/Impact Driver
Picked up a Rigid drill/impact driver combo kit with lifetime warrantee from Home Depot. Intend to use this on my stabilizers and any other AS related projects. The drivers are fairly small and light weight.
02-21-2016, 09:30 PM
1999 34' Excella
Hillsboro
Don't use impact unless you want to twist something off
Channing
WBCCI# 30676
02-22-2016, 02:43 AM
texas
A cordless drill works great. Get an extra battery.
If you are reading this, it means I have made it another day!!!
02-22-2016, 04:23 AM
"Cloudsplitter"
2003 25' Classic
Houstatlantavegas
, Malebolgia
Welcome Aboard....
X2
Battery?
02-22-2016, 04:34 AM
2020 28' Flying Cloud
Upper St Clair
, Pennsylvania
Drill, no impact. HD has a wide variety - least expensive you can find will do the trick. Just not too tight when the stabilizers hit the ground.
2020 28' Twin Flying Cloud
2021 F350 6.7 King Ranch
Thread |
Thread Starter |
Forum |
Replies |
Last Post |
steering stabilizer
ALANSD |
Mechanics Corner - Engines, Transmission & More... |
34 |
04-01-2014 09:48 AM |
Stabilizer Jack Installation
uwe |
Jacks, Stabilizers, Lifting and Leveling |
16 |
11-11-2004 05:39 PM |
Steering Stabilizer
rdm |
2 |
09-17-2004 06:03 PM |
steering stabilizer
cooperhawk |
3 |
07-17-2003 04:37 PM |
