Old 02-21-2016, 02:44 PM   #1
2016 28' Flying Cloud
New Port Richey , Florida
Stabilizer deployment
Just got our 2016 28 Ft Flying Cloud, dealer in Tampa Fl suggested I get a battery powered impact driver to lower and raise the stabilizers. Any thoughts or suggestions about best way to handle this?
afipita is offline   Reply With Quote
Old 02-21-2016, 03:09 PM   #2
drboyd's Avatar
1978 25' Tradewind
Metro Phoenix , Arizona
And I'll bet the dealer has one he'd be glad to sell you for only $999.99. Then you have to worry about keeping it charged and all that hooey. Get a crank handle speed wrench instead:
Old 02-21-2016, 03:17 PM   #3
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
I use a portable power drill. You can buy the attachment on line or at most hardware stores. Works great & just takes about one minute to lower or raise all stabilizers.
Joe
Venice, FL
2016 FC 25RTB
TAC FL-47
2016 Nissan Titan XD Cummins Diesel
Mrjkq is offline   Reply With Quote
Old 02-21-2016, 03:25 PM   #4
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
We use a quality compact power drill with lithium ion batteries. You can pick up the 3/4 inch socket to fit the drill at any camping store. We also use it to adjust our ProPride hitch weight distribution screw jacks, the snug them with a wrench. Easy peasy.
Doug and Cheryl
Old 02-21-2016, 03:36 PM   #5
1988 29' Excella
Plant City , Florida
The drill is the way to go I used a battery powered impact once it makes a lot of noise.
wjcwill is offline   Reply With Quote
Old 02-21-2016, 03:44 PM   #6
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Definitely use a drill. An impact driver will wake up the dead. We use a DeWalt 12 volt. It is more than powerful enough the handle Lucy's stabilizers. It can also handler the weight distribution bars on the Hensley.
We used to use a DeWalt 18 volt. The 12 volt is half the weight and does as well.
Brian
SuEllyn & Brian McCabe
Old 02-21-2016, 03:46 PM   #7
Ron A's Avatar
2018 23' Flying Cloud
Huntsville , Alabama
Using a drill for stabilizers. May want to use caution, not to firmly against the ground.
Ron
Ron A is offline   Reply With Quote
Old 02-21-2016, 03:49 PM   #8
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
I use a drill. The impact driver works better but is loud. I do not use the stabilizer all the time and never when we stay hooked up. Lithium ion drill is very handy as is the impact driver. I carry a kit that came with both and an extra battery.
Old 02-21-2016, 04:01 PM   #9
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Drill it!!!!! You will need a 3/4" socket to fit the stabilizer Screw head. Camco makes one which fits well into drill chuck and stabilizer screw head. See here: https://www.amazon.com/gp/aw/d/B001V...mco+stabilizer
Take care about the drill that you don't over tighten the stabilizers...that is not good for your Airstream as it will cause does and other stuff to not fit well.
Also, when you have almost deployed or retracted the stabilizer, the sudden stop can cause injury to you and Airstream siding/trim, etc.
I have my drill torque set low enough that it won't likely be uncontrollable.
Peace and Blessings..
Channing
WBCCI# 30676
Old 02-21-2016, 04:46 PM   #10
Cannonball's Avatar
2014 22' FB Sport
San Antonio , Texas
We use the crank handle that came with the Airstream. Never needs charging. Works every time. We just kneel on a work glove to save staining our evening wear. Contacts the ground, give it another 3/4 turn, or so. You will feel it.
Of course, we are kinda of nutty purists in certain respects. I still have two manual turntables and 1000+ vinyl albums in the stick-and-mortar.
Cannonball, Deep in the Heart of Texas!
WBCCI #4387, Air #84080
Cannonball is offline   Reply With Quote
Old 02-21-2016, 04:49 PM   #11
AnnArborBob's Avatar
2014 27' FB Eddie Bauer
Chelsea , Michigan
Images: 12
The cordless drill is definitely the way to go. Plus you'll have it on-board for other tasks. Not much other use for an impact driver in an RV.
Bob Martel
WBCCI# 5766
Old 02-21-2016, 05:02 PM   #12
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
I like the crank handle best. I always know where it is..... It doesn't need charging, etc, etc.
Of course, I like my antique drill brace, too, for making holes in stuff. It's way older than I am!
PaulnGina
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
Blessed and highly favored
“What’s good for me may not be good for the weak minded.”
1987 Avion 34W
PaulnGina is offline   Reply With Quote
Old 02-21-2016, 06:30 PM   #13
Free Range Human
Drathaar's Avatar
2012 25' FB Flying Cloud
Twin Rocks , Oregon
A drill works well, sometimes too well. Be careful to not over extend/retract the stabilizer. If you really jam it, it is a €%#& to free up. Don't ask how I know...
I'm quite fond of the speed handle these days.
Old 02-21-2016, 06:39 PM   #14
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
A drill would add weight and I'd have to carry the crank as a backup anyway. It's part of staying fit along with levering the sway control into position.
When I can't turn the hand crank, I'll get a drill. What ever it takes. Pat
steering stabilizer ALANSD Mechanics Corner - Engines, Transmission & More... 34 04-01-2014 09:48 AM
Stabilizer Jack Installation uwe Jacks, Stabilizers, Lifting and Leveling 16 11-11-2004 05:39 PM
Steering Stabilizer rdm Mechanics Corner - Engines, Transmission & More... 2 09-17-2004 06:03 PM
steering stabilizer cooperhawk Mechanics Corner - Engines, Transmission & More... 3 07-17-2003 04:37 PM
