Old 02-21-2016, 06:41 PM   #15
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
Use the factory supplied speed wrench on the Classic. Have some ⅛" roll pin on hand to replace the turning handle keeper when it finally shears off. Got a ⅜" spinner wrench at Harbor Freight and a swivel " shallow socket. I then use the Hensley supplied wrench to fine tune the left arms.
Tried the drill idea, but it's something else to keep charged. The battery tends to be low when I need to use it.....
Old 02-21-2016, 06:59 PM   #16
tsunami's Avatar
2016 28' Flying Cloud
Brandenburg , Kentucky
Images: 20
Drill/Impact Driver
Picked up a Rigid drill/impact driver combo kit with lifetime warrantee from Home Depot. Intend to use this on my stabilizers and any other AS related projects. The drivers are fairly small and light weight.
tsunami is offline   Reply With Quote
Old 02-21-2016, 09:30 PM   #17
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Don't use impact unless you want to twist something off
Peace and Blessings..
Channing
WBCCI# 30676
Old 02-22-2016, 02:43 AM   #18
GoWhereTowed's Avatar
texas , Texas
A cordless drill works great. Get an extra battery.
If you are reading this, it means I have made it another day!!!
GoWhereTowed is offline   Reply With Quote
Old 02-22-2016, 04:23 AM   #19
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up Welcome Aboard....
X2
Battery?
PFC
"Tahawus"
RLC
Its a crooked piece of time that we live in.
John Prine
Old 02-22-2016, 04:34 AM   #20
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Drill, no impact. HD has a wide variety - least expensive you can find will do the trick. Just not too tight when the stabilizers hit the ground.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 02-22-2016, 04:35 AM   #21
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
I use both the hand crank and my cordless drill. The drill to get close to the ground, and then the hand crank so I can feel the amount of pressure. I sometimes do the same thing in reverse when we leave so I don't close them too tightly. I charged the drill in December and its still working on that original charge. Its small and light, and stored in the original box right inside the door in the pull out drawer under the dinette.
SeaLevel is offline   Reply With Quote
Old 02-22-2016, 04:44 AM   #22
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Drill with a torque adjustment. Once you determine the proper torque, just run it until the clutch slips. Perfect every time.
2012 Dodge Durango Hemi/AWD
Old 02-22-2016, 07:18 AM   #23
extiger's Avatar
2011 30' Classic
Kingwood , Texas
I too use a cordless drill. Like others have said, set the torque and lower away. The drill has the torque setting while the impact driver does not.
I have been happy with the Ryobi family of cordless tools. In addition to a drill I also carry a Ryobi cordless blower, light and fan. All use the same size battery.
2011 30' Classic
2015 Ford F250 4X4 Platinum
ProPride Hitch
extiger is offline   Reply With Quote
steering stabilizer ALANSD Mechanics Corner - Engines, Transmission & More... 34 04-01-2014 09:48 AM
Stabilizer Jack Installation uwe Jacks, Stabilizers, Lifting and Leveling 16 11-11-2004 05:39 PM
Steering Stabilizer rdm Mechanics Corner - Engines, Transmission & More... 2 09-17-2004 06:03 PM
steering stabilizer cooperhawk Mechanics Corner - Engines, Transmission & More... 3 07-17-2003 04:37 PM
