Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Jacks, Stabilizers, Lifting and Leveling
Old 08-17-2007, 07:54 PM   #1
iAirstream
Profile:  2007 27' Safari FB SE
Land O' Lakes , Florida
Side to side leveling: can I use the stabilizer jacks?
I have a 28' Airstream. ('07:27-FB-SE)
Can I level small amounts (no more than 1 or 2 inches off) side to side with the stabilizer jacks. If so what should be the procedure. That is, should I level side to side first with the back jacks then stabilize with front jacks or should I reverse that or first do the lower side front and back?
Thank you for any help
iAirstream is offline   Reply With Quote
Old 08-17-2007, 07:59 PM   #2
SilverCabin
SilverCabin's Avatar
Profile:  2007 23' Safari SE
Viera , Florida
Welcome, but the answer is NO
iAirstream,
Welcome to the forums. The stabilizers are only for stabilizing the trailer so that it doesn't bounce when you walk around. Level it side-to-side first by pulling the wheels up on blocks or Linx Levelers (looks like big Legos, you can get them at Wal*Mart), then level front-to back with the jack. After the trailer is level you put down the stabilizers.
Randy
Randy and Pat Godfrey
2nd VP Florida Unit
WBCCI# 7591 - AIR# 17017
2007 Safari SE 23' - Daisy
2006 Lincoln Mark LT - Hoke
Read our Travel Blog at: www.silvercabin.net
A journey of a thousand miles, begins with a cash advance
SilverCabin is offline   Reply With Quote
Old 08-17-2007, 08:05 PM   #3
zamboni
zamboni's Avatar
Profile:
wouldn't it be nice if they just made the Fridge on a pivoting leveling system so when boondocking, you didn't really have to worry too much about leveling the entire trailer. Just a thought.
zamboni is offline   Reply With Quote
Old 08-17-2007, 08:14 PM   #4
KeithC
Profile:  1968 24' Tradewind
Mansfield , Georgia
iAIRSTEAM,
The most efficient way to level a trailer that my wife and I have found is to level the trailer from side to side first.
A 6" "bullet" level on larger on the center of the floor inside the trailer is good measurements side to side yaw. Use blocks to raise the tires for anything 1" or over.
Then use the front jack to raise or lower the tongue to verticle level.
A better absolute measurement of dead center is to place a "bullseye" level in the frig. Center the bubble and your are level.
A centered "bullseye" level in the frig. will ensure that your frig will work properly.
Stabilizer jacks should be let down to keep and maintain level.
KeithC is offline   Reply With Quote
Old 08-17-2007, 08:33 PM   #5
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
All the answers are on the money. Torquing up the stabilizers can also twist the chassis and aluminum body to the point that the main door will not close properly.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
How Tight - Stabilizer Jacks campadk Jacks, Stabilizers, Lifting and Leveling 6 05-05-2007 11:23 AM
Stabilizer jacks 1964 Overlander 64Overlander 1964 Overlander 3 01-13-2007 07:58 PM
Curved side window replacement michel88 Windows & Screens 7 09-29-2006 10:20 AM
need to replace both front stabilizer jacks charlie tuna Jacks, Stabilizers, Lifting and Leveling 12 08-23-2006 07:55 AM
side mirrors ALANSD Airstream Motorhome Forums 5 04-20-2002 08:38 PM
