Old 05-22-2008, 08:57 PM   #1
1981 31' Excella II
Hendersonville , Tennessee
set screw on power jack
I can't get the set screw loose on the power jack. Any suggestions?
mj81excella is offline   Reply With Quote
Old 05-22-2008, 09:11 PM   #2
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
Liquid wrench, WD-40 or similar, followed by tapping on the screw to set up vibrations. Let it soak good, trying it occasionally. May take a day or two to soak in and loosen up.
AIR #15800
"Wimpy" 1/2 ton 2002 GMC Sierra 4X4 Z-71 Gasser
2000 Safari SS 25'
Fyrzowt is offline   Reply With Quote
Old 05-22-2008, 09:11 PM   #3
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Check this out..Quite a few manual on power jacks..
Excellent tips on grease application, etc.
Our Products
Good Luck~!
53FC
53flyingcloud is offline   Reply With Quote
Old 05-22-2008, 09:17 PM   #4
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
There are a couple of ways to get threads loose.
The most necessary tool is patience.
Try some penetrating oil. Not WD40, get some real penetrating oil. Let it set over night and see if the treads are loose.
You can try heat. Sometimes just heating with a soldering gun and letting it cool a couple of times will break threads loose. The screw and the housing are of different materials, therefore expand and contract at different rates with heating and cooling. Usually this will separate the threads.
Another way threads can be broken free is with impact. If it is an allen head, put an allen wrench in the screw and tap on the wrench, not in the direction to turn the screw, but straight down the length of the screw. A pin punch that fits inside the allen head can also be used.
Sometimes I use all three. Heat, then soak, then a good hit.
The trick is to remove the screw without messing up the screw or the housing.
Patience.
Old 05-22-2008, 09:36 PM   #5
vswingfield's Avatar
1983 34' Excella
1967 24' Tradewind
Little Rock , Arkansas
Images: 32
Patience, penetrating oil, and heat. Heat it with a torch, spray with penetrating oil, and wait. Repeat as many times as necessary. If that doesn’t work, your are into the brute force techniques.
Vaughan
Old 05-22-2008, 10:00 PM   #6
Excella CM's Avatar
1978 31' Excella 500
Venice , California
You can use a little oil of wintergreen or you can mix a little automatic transmission oil and acetone as a penetrant. Mainly, as others have said, give it time to work. Another trick is to take a steel rod or punch the same diameter as the set screw and heat it red hot, then hold it to the set screw and let it transfer heat. this will oftenb do the trick where you don't want to apply a torch directly.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-23-2008, 05:22 AM   #7
1990 34' Excella
Parsonsfield, , Maine
Set Screw on Power Jack
If you have already sprayed something else on it this may not work. But Coca Cola is one of the most effective rust removers I've seen. The opening in the jack power head is larger than the top of the jack post. When in place and the set screw is tight, there should be some space between the head and the post. Whatever you use to loosten the rust, try spraying some up between the post and the head and try to soak the portion of the set screw that is in that gap. Good luck! CharlieE
CharlieE is offline   Reply With Quote
Old 05-26-2008, 08:38 AM   #8
1981 31' Excella II
Thank you for all your responses. I used the heat/oil/hammer technique and one screw came out the other stripped. Thats when I used just the hammer technique. I think the head softened the screw and I was able to work the jack up and off. It looks like I will have to drill out the one set screw and re-tap the hole. It should not be a problem. Thanks again for your help. Maybe on the next one I'll try the Coca Cola.
Old 05-26-2008, 08:59 AM   #9
richinny's Avatar
2011 34' Classic
you might try using an easy-out. it works best if you can drill out as much as possible without cutting the thread.
Ricky
Power Jack Fuses SilverGate Jacks, Stabilizers, Lifting and Leveling 41 04-01-2014 07:45 AM
power to my jack bill long Jacks, Stabilizers, Lifting and Leveling 6 11-25-2007 08:44 AM
power jack crowbar68 Jacks, Stabilizers, Lifting and Leveling 2 04-30-2006 10:22 PM
Frozen set screw guy99 General Motorhome Topics 2 06-15-2005 08:28 PM
power jack Tikihut Jacks, Stabilizers, Lifting and Leveling 3 03-20-2003 06:12 PM
