Old 06-16-2007, 02:41 AM   #1
77argosy24.SS
1977 24' Argosy 24
Sacramento , California
Self Leveling
Anyone out there added a self leveling kit to an airstream? Just curious what can be done? Does anyone know?
Thanks!
Scott Sterling
1977 Argosy 24
smsterling is offline   Reply With Quote
Old 06-16-2007, 05:24 AM   #2
Always Airstreaming!
rickandsandi's Avatar
2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
I had thought about it once and then between the price (List $700 per unit) and all the extra weight and then the hassle of installing, I have found a $30 B&D drill works fine for us.
Power Twin II Stabilizer®
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
Proud Member of WBCCI
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is offline   Reply With Quote
Old 06-16-2007, 07:31 AM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Don't do it
The only way to level an airstream is with the wheels and the tounge jack. The stabilizers are just that, to stabilize the trailer after it is level. To use the stabilizers or other frame jacks to level the trailer you would twist and flex the frame. A door that will not close is a good indicator that you have flexed the frame.
Richard
Old 06-16-2007, 08:34 AM   #4
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
I agree with Richard. Self leveling is a no no on an Airstream because the shell helps support the overall load/weight, not just the chassis like on other trailers. Even if you were to over torque your stabilizer jacks, you'd notice the door can also be difficult to open and close. Conventional leveling is key and almost any type of stabilization you'd like to add is fine, but not self leveling.
Old 06-16-2007, 08:50 AM   #5
Excella CM's Avatar
1978 31' Excella 500
Venice , California
You could custom build a hydralic lift set-up that would support the trailer in the same manner as the axels. Some of the homies in "East Los" could do it and give you the option of jumps and rolls too . Seriously, although it is possible to do, I cannot believe that it would be cost effective.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 06-20-2007, 11:27 AM   #6
77argosy24.SS
1977 24' Argosy 24
Self Leveling
Thanks... I have an Airstream Argosy Motorhome, not a trailer. Just looking for a self leveling kit I could install or have installed if it was possible and not crazy expensive.
Scott
Scott Sterling
1977 Argosy 24
Old 06-20-2007, 12:43 PM   #7
Excella CM's Avatar
Venice , California
I assume you could adapt something from a current class A
Old 06-20-2007, 01:17 PM   #8
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Huh?
You mean everyone does'nt have self leveling?????????
One button, push button, open beer, long swig..... Ta dah! level
Ah the joys of Class A ownership
Just teasin, I have had many AS's that did not self level,
but this one does.....
smily is offline   Reply With Quote
Leveling Boards Length? LabWagGun Our Community 11 09-18-2011 05:31 PM
Leveling a trailer APB On The Road... 29 07-11-2003 10:02 AM
hydraulic leveling system kooblekidz Airstream Motorhome Forums 4 02-27-2003 01:52 PM
Refrig. Heating Up rroessler Refrigerators 15 08-07-2002 05:46 PM
