Old 07-30-2015, 08:11 AM   #1
1972 31' Sovereign
1985 31' Excella
2010 31' Classic
Hendersonville , Tennessee
Scissor Jacks vs. Factory Ones
On our old AS I needed to replace the level jacks right away. So for the last 5 years I've using new scissor jacks. With our new(2010) AS the original jacks seem, well, kind of cheap and not as sturdy. Am I being to picky?
NashBuff is offline   Reply With Quote
Old 07-30-2015, 08:18 AM   #2
1972 31' Sovereign
1985 31' Excella
2010 31' Classic
Oops just finding a thread on this topic.
Old 07-30-2015, 08:33 AM   #3
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Stabilizers? They are not heavy duty load bearing and should not be used for attempting to level or lift the trailer.
MICHAEL
Old 07-30-2015, 08:50 AM   #4
Mission , Texas
Yep ... stabilizers ... not leveling - too flimsy.
nrgtrakr is offline   Reply With Quote
Old 07-30-2015, 09:18 AM   #5
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Yeah if you try to lift or level with them you'll end up ruining them. And then they don't do such a wonderful job, stabilizing.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 07-30-2015, 11:48 AM   #6
HoffmanP's Avatar
2014 27' FB International
Farmville , Virginia
Well, actually, I once forgot to crank my stabilizers up before I jacked up the tongue to hook up, and low and behold, the rear stabilizers held the whole weight of the trailer--wheels off the ground (a 27FB International). I always thought the stabilizers were a bit cheesy until then.
Paul Hoffman
2014 27FB International (WBCCI # 5327)
VA Plate: SOJOUNR
2013 Ford F-150 XLT Super Cab (Silver)
VA Plate: WYO2VA
HoffmanP is offline   Reply With Quote
Old 07-30-2015, 11:53 AM   #7
AWCHIEF's Avatar
Images: 33
Lucky!
MICHAEL
Old 07-30-2015, 12:47 PM   #8
Nomadic , USA
Yeah I'd say that's lucky, my back corner one took some weight and now it always ends up loose after a few days of going in and out of the Airstream.
Old 07-30-2015, 03:52 PM   #9
Vintage Kin
Fort Worth , Texas
Curb side?
They're easy to replace. Is the ACME screw thread damaged? If so, place more material underneath to avoid that thread section.
And it's normal to re-adjust them after a couple of days till the trailer "takes a set". It's also a benefit of using 6'x12"x2" pressure treat under tires. Spread the load across the dirt.
The little plastic thingies won't do it.
ROtochoks (well worth eBay auction) or similar will help stop trailer rock and remove pressure spikes on stabilizers.
Trailers are usually heavier on curb side. If you can support steps with wood block, that also stops rocking.
Old 07-30-2015, 03:54 PM   #10
Vintage Kin
Fort Worth , Texas
You'll want to ask Andy/Inland RV for expert opinion. I personally would never use the type on one of my trailers.
See above post and research ROtochoks.
Old 07-30-2015, 06:01 PM   #11
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
I agree with slow-mover;
The AS stabilizers are rather flimsy looking, and I prefer the more sturdy scissor jacks. Having said that; I have just received a new 25' Flying Cloud, and after three trips on it, the 'cheezy' stabilizers seem to work ok. But I'll be monitoring their performance in the future.
MelGoddard is offline   Reply With Quote
Old 07-30-2015, 08:58 PM   #12
Vintage Kin
Fort Worth , Texas
I'm not at all in favor of screw jacks, sorry I did not make myself clear.
The stab type are more than adequate especially when bolstered by intra-tire chocks of substantial size, and more marginally by equalizing axle movement via a wood plank.
Old 07-30-2015, 09:18 PM   #13
1971 31' Sovereign
1973 29' Ambassador
1978 31' Sovereign
Palm Desert , California
I googled ROtochoks. They went out of business last year.
CaCraig is offline   Reply With Quote
Old 07-31-2015, 03:30 AM   #14
Vintage Kin
Fort Worth , Texas
Yes. We're limited to trying to find the right size via classifieds or online auctions.
Old 08-01-2015, 07:40 AM   #15
2002 22' International CCD
kennebunkport , Maine
While on the left coast, had my favorite A/S dealer, Tuscan RV replace the flimsy, stock stabilizers with electrically operated stabilizers. It is now a pleasure to lower and retract them.
Maine-yak
frechette is offline   Reply With Quote
Old 08-01-2015, 07:56 AM   #16
1971 31' Sovereign
1973 29' Ambassador
1978 31' Sovereign
What are these flimsy stabilizers everyone is talking about? The ones that have the foot that comes down on all four corners? I was just about to buy a set of those from Vintage. They are rated at 2000lbs each. That's more than enough to stabilize and even raise my AS off the ground.
Maybe I should just get the pyramid shaped ones that are $40 for the set? I just didn't want to have to store something else inside.
Old 08-01-2015, 08:30 AM   #17
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
The Airstream needs to be leveled with some sort of leveling block(s) under the tire(s) and the tongue jack. It needs to be stabilized with the four stabilizers, which can easily be run down and up with a electric drill and socket. Unless it's just an overnight stop; we leave it hooked up to the truck with no jack or stabilizers down. The factory stabilizers are plenty substantial for their purpose.
I see that Can-Am Airstream in Ontario installs electric leveling struts near the wheel wells, that's about as easy as this can get and it's on my mind (due to advancing years) to alleviate the leveling nuisance.
Doug and Cheryl
Old 09-18-2015, 08:36 PM   #18
:SPACE A" S/O 11 Air19745
guskmg's Avatar
2006 34' Classic S/O
Fort Worth , Texas
I hate to rain on your parade, but CanAm just told me their supplier for the new wheel jacks is no longer shipping them.
guskmg
Big ones or little ones...which is better? Phrunes LP Gas, Piping, Tanks & Regulators 20 03-07-2013 07:36 AM
Replacing original stabilizers with scissor jacks FishHouse Jacks, Stabilizers, Lifting and Leveling 1 10-25-2010 04:14 PM
Scissor Jacks in Front? J Goertzen 2002 - 2005 International 1 07-02-2008 01:46 PM
Scissor jacks/unhitching J Goertzen Jacks, Stabilizers, Lifting and Leveling 3 06-24-2008 04:55 PM
Scissor Jacks on 23' Safari SE LS OrangeKid 2007 Safari SE 10 11-14-2006 04:37 PM
