Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Jacks, Stabilizers, Lifting and Leveling
Old 06-24-2008, 05:37 PM   #1
J Goertzen
Profile:
Scissor jacks/unhitching
Howdy FriendsI've got a 2003 International, 22',CCD. Have been using jack stands to keep the AS up when its unhitched from the TV. I am new at this. These stands are a pain to set up, are heavy to move around for my old back. I noticed I am the only one using these in a campground, (Duh!). Now have discovered "scissor jacks". Is this a good way to go? How best to install them, bolted on or solder on the tongue ? These would appear to be the way to go when unhitching the AS at a campground and you want to drive around and explore local area. This would make the camping experiece much better and easier on my back. Anyother ideas out there? Thanks, Jim
J Goertzen is offline   Reply With Quote
Old 06-24-2008, 05:53 PM   #2
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
Most travel trailers have tongue jacks that are lowered to lift the tongue off the trailer ball. It should be located directly behind the spot the ball goes, and just ahead of the LP tanks.
Old 06-24-2008, 05:54 PM   #3
CanoeStream
CanoeStream's Avatar
St. Cloud , Minnesota
Images: 13
Mmmm? You don't have BAL jacks? I know these 22' CCDs were trial trailers -- one-piece chipboard floors, some didn't even have bellywrap (instead having a membrane between the frame and the floors).
The BAL jacks most AS owners expect are not the normal ones available at local RV dealers -- AS trailers require longer shafts to get past the curve at the belly-side junction. I'd think an Airstream dealer could install them in very little time.
Old 06-24-2008, 05:55 PM   #4
CanoeStream
Images: 13
Terry, you read this better than I. Better draw me a picture...
**Leveling Jacks** Silvertwinky General Motorhome Topics 31 05-16-2008 05:53 PM
Scissor Jacks on 23' Safari SE LS OrangeKid 2007 Safari SE 10 11-14-2006 05:37 PM
Stabilizing Jacks FIREBOSS16 Jacks, Stabilizers, Lifting and Leveling 2 08-29-2006 11:52 PM
Stabilizer Jacks--what should we get? Laure&Chuck Jacks, Stabilizers, Lifting and Leveling 12 11-15-2005 05:07 PM
stabilizing jacks emanon25 Jacks, Stabilizers, Lifting and Leveling 0 09-04-2004 10:53 AM
