Old 03-31-2010, 12:10 PM   #1
jwisland's Avatar
2001 31' Land Yacht
Spokane , Washington
Scissor Jack levelers
Hi all,
Has anyone used these to level a Class A Land Yacht 30 MH with a P32 Workhorse chassis? There are 4 points I can weld them to, but curious if anyone has had any problems with leveling a Class A with scissor jacks. Link follows:
Scissor Jacks Stabilizing System - Item - Camping World
I'd be using 4 of the 24002D with a 7500# each rating. My GVWR is 18,000.
Jeff
2001 LY 30
'86 Samurai toad
StowMaster tow
SMI Duo braking
jwisland is offline   Reply With Quote
Old 03-31-2010, 12:20 PM   #2
_
hi jeff
those are STABILIZING jacks, not LEVELING jacks.
big difference...
BIG difference.
also that STYLE (even if just used for stabilizing) will significantly reduce GROUND CLEARANCE...
especially at the rear.
not a great choice for the moho...
cheers
2air'
Old 03-31-2010, 12:46 PM   #3
jwisland's Avatar
2001 31' Land Yacht
2air,
Folded up they will be about an inch higher than my Reese hitch. True......they're stabilizing jacks....(my bad)... just looking to keep the wind sway down at night. Any reason you think I shouldn't use them for that purpose? Plus.....even if I did crank them up to raise a corner an inch or two.....is it dangerous? Any other types I should be looking at that won't break the bank?
Jeff
2001 LY 30
'86 Samurai toad
StowMaster tow
SMI Duo braking
Scissor Jacks in Front? J Goertzen 2002 - 2005 International 1 07-02-2008 01:46 PM
Scissor jacks/unhitching J Goertzen Jacks, Stabilizers, Lifting and Leveling 3 06-24-2008 04:55 PM
Scissor Jacks on 23' Safari SE LS OrangeKid 2007 Safari SE 10 11-14-2006 04:37 PM
Airbags and self-levelers fangthorpe Mechanics Corner - Engines, Transmission & More... 7 08-12-2003 10:16 AM
