Old 10-16-2017, 01:48 PM   #1
Mollysdad's Avatar
Rotating the jack 90 degrees. (Math test)
Okay, help me think out loud.
The current coupler has holes for the jack drilled and tapped at 0 degrees, 120 degrees, and 240 degrees (with zero facing forward.)
So if I drill new holes in the jack flange, but want the jack facing the driver's side and parallel to the propane tanks, I'd add holes at 30 degrees, 150 degrees, and 270 degrees on the jack post flange.
Basically, adding 30 degrees past the existing holes.
So when I turn the jack 90 degrees, my zero hole will be at 90 and I want a new hole at 120 or another 30 degrees.
Agree?
I confess I took two pieces of paper, one was the coupler holes and the other the jack flange and turned it.
Old 10-16-2017, 02:05 PM   #2
2007 22' International CCD
Your math sounds correct, but I would mark the holes, and test fit before you drill.
I must admit that I would have just made a stiff cardboard pattern from the existing holes, slit it with a center hole for the jack post clearance, twisted it into the 'right' position, and marked the new holes off on the flange. With my mild dyslexia, I would probably have ended up with a few extra new holes... Especially if I worked from the bottom of the jack flange (sigh).
Then I would have drilled them a bit bigger than needed, and filed/bashed to fit as needed. Bunch of appropriate star-type lock and flat washers, all in stainless, plus stainless bolts and nuts.
Fortunately, with my much longer ProPride hitch setup, the jack motor is well clear of the tailgate, so I haven't had to do this yet...if I get wild and get a flagpole holder, I'll have to do this...
Old 10-16-2017, 02:38 PM   #3
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I think you are right, but I'm having a terminology problem. Degrees are typically specified as clockwise from 0. If 0 is straight ahead referenced to the trailer and you turn the jack 90 degrees ccw to face the road side it will put that hole at 270. The closest hole in the frame is at 240 degrees. So you need new holes at 30 degrees ccw from the existing holes.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 10-16-2017, 04:37 PM   #4
Mollysdad's Avatar
Al
Yes. I went CCW because I wanted the jack turned 90 degrees and ending up facing the driver's side and saying "turn it 270" seemed counterintuitive. (but correct)
I will, but the trailer is not at the house, so I wanted to think it through before loading up the tools.
Old 10-16-2017, 07:19 PM   #5
2016 28' Pendleton
East central , Illinois
You might try using transfer screws (self aligning center punches for threaded holes). Just mark the circumference of the jack as it is, then remove the jack, install the transfer screws, position the jack in your desired location/position and tap the flange above each of the transfer screws with a hammer. Now all your holes are marked on the underside of the flange. Just drill your new holes at the punch marks and you are guaranteed a perfect fit. You can find the transfer screws at McMaster Carr or any number of other industrial supply sources. They are pretty inexpensive and make this type of job much easier.
GinaNBob is offline   Reply With Quote
Old 10-16-2017, 07:43 PM   #6
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Stooooooooppppppppp!!!!!!
Agree?
DO NOT DRILL HOLES. TO TURN THE HEAD OF THE JACK ALL YOU HAVE TO DO IS LOOSEN THE ALLEN SET SCREWS AND ROTATE THE JACK HEAD. NOT THE WHOLE JACK!!!!!
Very easy to do. It will take less than 1 min to complete the job.
GMFL is online now   Reply With Quote
Old 10-16-2017, 07:45 PM   #7
GMFL's Avatar
Dadeville , Alabama
Head rotates and is locked in place with 3 Allen set screws
Old 10-16-2017, 07:59 PM   #8
2014 23' Flying Cloud
Park City , Utah
As just mentioned before this post...why do geometry and then drill holes? Your jack should have 3 allen screws near the top under the main gear assembly. Removed your propane tank cover, loosen those, then rotate the jack. Tighten screws. Done.
pcskier is offline   Reply With Quote
Old 10-17-2017, 09:40 AM   #9
Mollysdad's Avatar
You know we're talking about the Husky Super Brute 4000/5000, yes?
Where are these three set screws you speak of?
Old 10-17-2017, 09:51 AM   #10
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
I thought GMFL and PCSKIER had it solved til you complicated it with changing the jack brand from what we were apparently thinking. I have the almost original Barker on mine (first one failed a few months in) and spinning the head 90 deg was simple.
And I wish I'd thought of rotating it to driver's side instead of curb side. All these years I've been reaching over the top and operating the up/dn switch from wrong side. Too funny, and easy to fix on mine (I hope). On the other hand, maybe shouldn't disturb this venerable old jack now. It's working fine as is.
I love the transfer screws idea. Never heard of it. Air Forums rocks!
Chasing 75 Degrees,
Jim N5RTG
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Old 10-17-2017, 10:09 AM   #11
dznf0g's Avatar
Oswego , Illinois
Contact Husky. I gotta believe there is a way to rotate the head.
-Rich-
Old 10-17-2017, 10:42 AM   #12
Parker , williamdcrockett
agree. You can loosen the allen screw and rotate the head on the jack that airstream uses on this trailer. That is how I rotated the jack on my 2012 27FB. Maybe his 2017 27FB is using a different jack.
wcrockett is offline   Reply With Quote
Old 10-17-2017, 11:26 AM   #13
Slide Out Society #001
GCinSC2's Avatar
2007 30' Classic S/O
Somewhere , South Carolina
But to figure the X Y coordinates for drilling is it sin or cosin pos or neg when rotate CCW and viewed upside down. And is it the same if your in the Southern Hemisphere.
Got to figure it out folks!
S/OS #001
2005 Dodge Ram 2500 5.9L 6 Speed
16" Michelins, Hi Spec Wheels, Max Brake, Carslile Actuator, Equal-i-zer, Dill TPMS. Campfire cook.
GCinSC2 is offline   Reply With Quote
Old 10-17-2017, 11:39 AM   #14
Mollysdad's Avatar
Airstream is using an Atwood 4000.
It has a triangular base, so drilling new holes is not possible. Rotating the head would be nice but I can't see how.
I picked the Husky because of the good reviews and the price is better than the Barker.
40" UHD 4K TV Rotating Mount BASE729 Audio, Video & TV 7 03-25-2015 06:53 PM
Rotating Tires moosetags Tires 3 07-24-2011 10:06 AM
Rotating a 29-footer by hand? mikeandnora General Repair Forum 18 02-03-2011 12:16 PM
Carrier A/C rotating vents jkcru Furnaces, Heaters, Fireplaces & Air Conditioning 2 08-30-2007 07:43 AM
Microwave rotating dish in transit.... Silvertwinkie Off Topic Forum 15 04-23-2004 03:50 PM
