Old 11-22-2009, 04:56 AM   #1
mistermike's Avatar
1968 17' Caravel
Marblehead , Hasslechusetts
REQ: Advice Repairing an Electric Ultra 35xx Jack
I recently acquired a 1968 CARAVEL with an Ultra 3500 series electric tongue jack. The previous owner told me that the jack was not operational and the problem is quite common with these jacks. He gave me the part that needs replacement so all I need to do is install it. It is called a "headed pin".
I downloaded the installation documentation from the manufacturer but the exploded diagram does not show me how this "headed pin" is installed. From the diagram it would appear that it goes on the large gear just over the housing cover. However I do not see where the round pin goes or what it does.
I'd appreciate it if someone who has replaced this "headed pin" on their Ultra Jack could advise me on how to install it.
Michael, (W1RC)
mistermike is offline   Reply With Quote
Old 11-22-2009, 07:02 PM   #2
Kevin245's Avatar
Michael,
I believe you must pull the pinion gear shaft from the spur gear to access the shear pin. Is this the documentation you are talking about?
Regards,
Kevin
Eleanor Roosevelt
Old 11-23-2009, 03:49 AM   #3
mistermike's Avatar
1968 17' Caravel
Hi Kevin:
Thanks for the info. I will probably call their tech support today and find out how it is done.
Regards,
Michael
Barker or Ultra-Fab electric jack? SmokelessJoe Jacks, Stabilizers, Lifting and Leveling 30 05-08-2018 10:45 PM
Installing a new ultra 3002 electric tongue jack on my 65 Caravel toastie Jacks, Stabilizers, Lifting and Leveling 3 03-15-2007 11:10 AM
Electric Jack scf31 Jacks, Stabilizers, Lifting and Leveling 2 06-18-2006 06:16 AM
Electric Jack Dbraw Jacks, Stabilizers, Lifting and Leveling 17 05-22-2006 05:33 PM
Ultra-fab power jack? drboyd Jacks, Stabilizers, Lifting and Leveling 0 09-08-2003 09:57 PM
