Old 11-23-2008, 02:29 AM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
replacing manual tongue jack with electric
This must be an ancillary to Murphy's Law, when you think it's going to be easy it won't.
Got a Barker Electric tongue jack to replace the original Atwood manual jack on my 71. Apparently just in time because when I jacked up the tongue with a bottle jack the inner ram fell out from the bottom of the Atwood. I was surprised that after I removed the 3 bolts holding the old jack to the tongue it did not want to go anywhere. Looking under the tongue there is a welded plate the jack also fits through.
1. Is the jack just rusted to the lower tongue plate or permanently attached?
2. The 3 mounting holes on the new Barker should line up with the old holes in the tongue, right?
3. The Barker should fit through the hole in the lower tongue plate, right? Or will I have to do some cutting and grinding?
Marshall
Old 11-23-2008, 07:02 AM   #2
SteveH's Avatar
Common Sense , Texas
Marshall
Marshall,
I have not seen the jacks attached to the lower plate, but that does not mean yours is not.
Yes, the bolt holes should line up with your new jack. And, the new jack should also fit thru the hole in the lower plate also. The key word here is "should".
Good luck with the jack change-out.
Regards,
Steve
Old 11-23-2008, 07:31 AM   #3
Lumatic's Avatar
1993 34' Excella
Images: 16
If it doesn't fit get a bigger hammer
OK. A good soak with WD 40 and assertive blows to the recalcitrant jack with a big hammer and it is moving, in the right direction, up. There is 0 clearance between the ID and ODs of the jack and the hole.
Old 11-23-2008, 08:27 AM   #4
Janets Husband's Avatar
1977 Argosy Minuet 6.0 Metre
1964 26' Overlander
1977 25' Tradewind
Eastern , Washington
Tight
I have found that they are all tight. It will come but some force may be required. One thing that has happened to me is the outer tube was damaged and it flared out some, this required a Sawsall to lop off the bottom of the jack being removed. Look for dents in the outer tube.
Peace
Gary
Janets Husband is offline   Reply With Quote
Old 11-23-2008, 12:52 PM   #5
Lumatic's Avatar
1993 34' Excella
Images: 16
Goterdun!
The bottom of the jack was burred from hammering on it trying to get it out. Got the burrs off with a grinder.
I also used the tongue weight with a bottle jack under the old jack which finally popped her out.
Similarly the lower plate hole was a smidge too tight and I ground off a little metal until I could get it in. I didn't have to take off much, probably the thickness of a piece of paper or less.
Old 11-25-2008, 07:04 AM   #6
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Mine has spot welds. So to get it out there will be some grinding involved. I checked this out in the event I had to replace my OE power jack. Fortunately it was only a switch and not the jack. Not bad for a 42 yo power jack to be still working.
>>>>>>>>>>>>>>>>>>>Action
manual crank for 1964 electric tongue jack Croverlander 1960 - 1964 Overlander 15 04-09-2014 11:10 AM
Electric tongue jack help RVnDixie All Argosy Trailers 8 12-31-2006 08:54 PM
Manual Tongue Jack Failure Sugarfoot Jacks, Stabilizers, Lifting and Leveling 38 11-30-2006 07:09 AM
Electric Tongue Jack darryl97420 Jacks, Stabilizers, Lifting and Leveling 0 05-25-2006 08:57 PM
Electric tongue jack not extending ipso_facto Jacks, Stabilizers, Lifting and Leveling 5 03-25-2003 11:58 AM
