Old 08-27-2016, 08:35 AM   #1
streamerfred's Avatar
Replacing jack...install questions on a 75 Sovereign
Our electric jack has died and we need to install new one. Questions:
1) easy to install ourselves?
2) any brand recommendations?
streamerfred is offline   Reply With Quote
Old 08-27-2016, 08:42 AM   #2
GLCMRANGER - Sue
2016 25' International
Littlestown , Pennsylvania
yes. I just replaced my Atwood Premier 3000 (factory installed) with a Atwood Premier 4000. I needed the extra power so I could jack up the tongue for my WD bars. Works great. Here's lessons learned.
1) On the base plate, make sure you place the "Star Washers" on top of the trailer's 3 holes. If there is paint around the holes, file it off. This will ensure a good ground for the jack and you won't have problems later on. When I removed the old jack, the factory only put 1 Star washer on one out of 3 holes.
2) But a yellow "ring connector". This needs to be crimped on to the end of the cable. It will slip over the battery terminal nut. If you're unsure, just duplicate what the connector looks like from your old jack.
3) The only tough part was fishing the new jack wire to the battery underneath.
The cost of upgrading to a 3500 or a 4000 is negligible... spend a couple extra bucks. Don't replace with the 3000 equivalent. Mine always struggled...
glcmranger is offline   Reply With Quote
Old 08-27-2016, 08:45 AM   #3
2016 23' International
Salem , Oregon
Jack
You don't say what year your trailer is but I would think most would be an easy job. Mine is held on with three bolts. Support the front with jack stands or another means after lifting the weight off with a portable jack.
I have a Atwood jack on mine. They are used on many of the newer models. You may want to check with them for a model suitable for your trailer. \
You many need to splice a couple wires. Should be able to complete yourself in a hour.
Dave
NoResults is offline   Reply With Quote
Old 08-27-2016, 08:55 AM   #4
Hi Dave it is a '75 sovereign. Thanks for your response
Old 08-27-2016, 08:59 AM   #5
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
It is an easy job.
You know what is kinda funny?
The jack is held on by three 5/16" bolts which bear the entire weight of the trailer tongue and whatever else the tongue is hooked to. (I think about those three bolts any time I work under the tongue area of my detached trailer)
My only advise is if the three studs or bolts are replaced, go with grade 8 bolts....
Gradiens super tenui glacie.
Old 08-27-2016, 11:37 AM   #6
1976 31' Sovereign
Oswego , Illinois
There should be sleeve in lower plate as AS used smaller dia. jacks those years, you will not need sleeve. Pur. 3500 jack not smaller I use Barker, there are several brands. Simple hook up, 1 wire ties into break away swt. no need to run separate wire to batt. as break away swt. only uses power if plunger pulled setting brakes. Support a frame 3 bolts must use star washer provided w/new jack as this is ground. Pur. new grade 8 bolts & nuts, lock washers.
Old 08-28-2016, 10:40 AM   #7
Michael Wild
1978 31' Sovereign
1984 31' Airstream310
Edmonton , Alberta
Stuck?
When I removed the three bolts that hold on my tongue jack, it didn't budge. I did not get too rough with it as I was not sure if I was going to replace it or not. Any tips on getting it free?
planBe is offline   Reply With Quote
Old 08-28-2016, 10:42 AM   #8
Michael Wild
1978 31' Sovereign
Edmonton , Alberta
Where to buy?
Could everyone supply prices and links to where they bought their new tongue jacks?
Old 08-28-2016, 11:09 AM   #9
SeaLevel's Avatar
2016 25' Flying Cloud
Jupiter , Florida
Just under $225 right now on Amazon for the 4000# Atwood:
https://www.amazon.com/Atwood-0149-1...ood+power+jack
Or a little more for the one with the robofoot:
https://www.amazon.com/Atwood-81069-...JKDAXREZT1JG4Y
SeaLevel is offline   Reply With Quote
Old 08-29-2016, 07:45 AM   #10
1976 31' Sovereign
Oswego , Illinois
Smile
The sleeve on jack for bottom plate is holding jack from being removed. I don't remember if was pressed onto jack but was hard to remove from tongue. Bill
Old 08-29-2016, 08:02 AM   #11
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I just purchased a 4000lb Atwood jack with their Robofoot from etrailer. Amazon is a little cheaper. While I got free shipping too I didn't realize eTrailer is in Missouri and got dinged for sales tax. Its a one wire hook up like the previous Barker which was sounding like it would explode when retracting. The Robofoot folds up when retracting. Don't have to bother with putting on or taking off a foot now. I like it.
Kelvin
sovereign
To Jack or not to jack? Zstream Jacks, Stabilizers, Lifting and Leveling 7 12-17-2009 11:09 AM
Questions, Questions, Questions LowellN Repairing/Replacing Floor &/or Frame 5 10-28-2004 07:23 PM
Manual Jack Broken - Best Elec. Jack? montanaandy Jacks, Stabilizers, Lifting and Leveling 9 07-10-2003 06:33 AM
Jack Plates Jack Plates Inland RV Center, In Our Community 4 03-19-2003 03:34 PM
