Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Jacks, Stabilizers, Lifting and Leveling
Old 09-05-2009, 10:16 AM   #1
Profile:  1974 27' Overlander
Berryville , Virginia
repair trailer jack
I have a 74 land yacht which has a lift on it which appears to be a hydrolic type of lift. Its not the manual crank type or electric. it has a lever which near as I can tell would push the lift tube down to raise the A frame. Problem I have is the gaskets are shot, so it does not lift anymore. Can this be rebuilt or do you just unbolt the whole thing and replace it with a new jack? who sells the jacks if that is the case? Thanks,Barry
batt is offline   Reply With Quote
Old 09-05-2009, 10:40 AM   #2
Profile:  1998 28' Excella
Dolores , Colorado
Barry
Welcome to the forums. This is the place to get information about your A/S
I have never seen a hydraulic jack. However any good rv shop would be able to sell you an electric jack to replace it. I had to put a new one on my 71 unit a few years back. Cost was about $265
Good luck
4CU/CAC
dogpound is offline   Reply With Quote
Old 09-05-2009, 11:06 AM   #3
Shacksman's Avatar
Profile:  1967 22' Safari
1973 Argosy 26
1960 28' Ambassador
Avonton , Ontario
I have a hydraulic jack on my 60 trailer. It needed a new O ring and some oil and works great.
Doug
WBCCI #3327 - VAC
73 Argosy
67 Safari
60 Ambassador Int.
Shacksman is offline   Reply With Quote
Old 09-05-2009, 11:12 AM   #4
Alwhisman's Avatar
Profile:  1978 Argosy Minuet 7.3 Metre
Dayton , Texas
Images: 70
Airstream Registry
Send a message via Yahoo to Alwhisman
I haven't seen the hydraulic type, but should be easy to rebuild. I prefer the electric jack because theres less effort required.......I'm basically lazy!
Is there a name brand on it anywhere?
Al
Alwhisman is offline   Reply With Quote
Old 09-06-2009, 04:45 PM   #5
how did you disassemble the jack. I could not find any way to pull it apart. the top cylander looked like it was welded to the shaft. Where do you fill it with jack oil?
Old 09-06-2009, 04:50 PM   #6
Shacksman's Avatar
1973 Argosy 26
1960 28' Ambassador
Avonton , Ontario
I took the piston out that the handle pumps. In there is an O ring. Mine has a screw on the side that you can remove to put oil in. I'll see if I can get a picture for you.
Doug
WBCCI #3327 - VAC
73 Argosy
67 Safari
60 Ambassador Int.
Old 09-06-2009, 05:32 PM   #7
Shacksman's Avatar
1973 Argosy 26
1960 28' Ambassador
Avonton , Ontario
Here's the jack. Pumps up fast and lowers even faster. Only problem is in the cold the oil is thick.
ID:	86714   Click image for larger version
Doug
WBCCI #3327 - VAC
73 Argosy
67 Safari
60 Ambassador Int.
Old 09-07-2009, 08:02 AM   #8
OK, is the piston in the cylinder that is on top of the jack? If that's it how do you get it off? is it threaded? It looked like it was welded to the jack column. In cold weather you can use an oil which is lighter. Glad to hear it works well, hope you can advise me on disassembling the unit. Thanks, Barry
Old 09-07-2009, 08:15 AM   #9
Shacksman's Avatar
1973 Argosy 26
1960 28' Ambassador
Avonton , Ontario
Barry if yours looks like mine, undo the bolt holding the handle pump and pull out the piece that goes in and out. Inside that hole is the O ring that I replaced. That's all I can get apart. The rest is one piece.
Doug
WBCCI #3327 - VAC
73 Argosy
67 Safari
60 Ambassador Int.
Old 09-07-2009, 08:40 AM   #10
SARGE/AF's Avatar
Profile:  1976 31' Sovereign
Greeneville , Tennessee
I know that I can help here, my father had a welding business back from the 40's-70's and we did alot of work on heavy equipment and many times we had to fix these cylinders. Around 68-69 we just started replacing them with other cylinders and send the broke ones to be either junked or repaired because it was cheaper to replace, not only that if you did not do it properly when welding you cooked the oil & ruined the seals.
Actually they can be disassembled but must be done by a hydrolic shop. In those days the hyd cylinders when assembled was welded together because at that time they thought it made them stronger. Any shop that makes or repairs hyd cylinders should be able to fix for a fair cost. If you dont have a place near you that repairs these cylinders look for a place that deals with and repairs dozers, backhoes, etc.
I do know that if you take the bolts off where it mounts to the frame and turn it upside down you should see a place where it allows the hyd cylinder to come out so it can repaired or replaced after the pump part on the handle has been removed.
Sarge
SARGE/AF is offline   Reply With Quote
Old 09-07-2009, 08:45 AM   #11
Distantdrummer's Avatar
Profile:  1975 31' Sovereign
Houston , Texas
Have never seen mention or certainly pic of this item before. Been around various RV forums for a long time. Very interesting. Would like to hear more about whether this was a stock (or even Airstream offered option) product.
Apparently they were around from at least '60 til '74.
Inland Andy might know, but OH I forgot, he is banned from participation.
__________________________
____ d'drummer ____
...aahh..rumm..pu..tum..tummm...
Distantdrummer is offline   Reply With Quote
Old 09-07-2009, 10:58 AM   #12
Shacksman's Avatar
1973 Argosy 26
1960 28' Ambassador
Avonton , Ontario
Mine came off a 67 that I bought for parts. I've seen 2 others, both were on early 70's Airstreams. I imagine that they were aftermarket items. I even saw a modern one advertised in a parts book a few years ago but can't find it now.
Doug
WBCCI #3327 - VAC
73 Argosy
67 Safari
60 Ambassador Int.
Old 09-07-2009, 11:10 AM   #13
Shacksman's Avatar
1973 Argosy 26
1960 28' Ambassador
Avonton , Ontario
Hydraulic Tongue Jack TJ 001
Here's the closest thing in a modern jack that I find.
Doug
WBCCI #3327 - VAC
73 Argosy
67 Safari
60 Ambassador Int.
Super Jack repair dedko Jacks, Stabilizers, Lifting and Leveling 6 12-27-2009 09:45 PM
Power Jack Repair DanB Jacks, Stabilizers, Lifting and Leveling 4 07-31-2007 09:01 AM
Help with trailer jack Chaplain Kent Electrical - Systems, Generators, Batteries & Solar 1 07-14-2004 10:17 AM
jack nife - front skin repair - parts ? JimWeed Ribs, Skins & Rivets 3 12-31-2003 12:01 PM
Tongue Jack Repair dinoburb Jacks, Stabilizers, Lifting and Leveling 7 03-27-2003 05:15 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
