Old 01-21-2008, 08:05 PM   #1
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
I am trying to remove the jack off my 67. The 3 bolts are out.
Jack will not budge. Trailer is hooked up to the TV.
I cranked the jack up a bit, tapped it with the hammer, still nothing.
Maybe it is the years of paint?
I do not think it's welded on.
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 01-21-2008, 08:19 PM   #2
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
It is likely rusted in place. Have you tried rocking back and forth?
Michelle TAC MT-0
Sarah, Snowball
Old 01-21-2008, 09:01 PM   #3
Darol Ingalls's Avatar
Look at the underside of the A-frame where the jack tube goes through the bottom plate. Some were welded to the bottom plate from below. Why?? To make things difficult, of course. Darol
Darol Ingalls is offline   Reply With Quote
Old 01-22-2008, 05:21 PM   #4
Vince & Virginia
Towster's Avatar
1969 21' Globetrotter
Riverside , California
Forget about "tapping" it with a hammer.
You need to "whale" on it with a sledgehammer.
It worked for me.
Virginia
Towster is offline   Reply With Quote
Old 01-22-2008, 05:34 PM   #5
Kajtek1's Avatar
1965 22' Safari
Orinda , California
If I recall the jack goes thru small pipe in the tongue, that makes corrosion lock. Spray it with PB and leave it for a day.
Kajtek1 is offline   Reply With Quote
Old 01-22-2008, 06:04 PM   #6
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
THEN whale on it with a sledgehammer...
Old 01-22-2008, 06:09 PM   #7
Kajtek1's Avatar
1965 22' Safari
Orinda , California
Not if you are lucky. I was using PB on my vent jacks. One was stubborn. I was able to un- freeze the center shaft, but the middle sleeve would not move even with hammer tapping. I figured out that 1/2 way up is good enough and have it reinstalled. The following day I was opening the vent and the middle sleeve moved with finger push.
Old 01-22-2008, 06:18 PM   #8
Well Preserved
1993 21' Sovereign
I'm never that lucky... It's always sledgehammers, torches, 20-mule teams, 800 pound gorillas, etc.
Remind me to tell you somtime about the fun I had getting a recalcitrant hitch head out of a receiver...wound up dragging a dumpster down the street by it...
Old 01-22-2008, 07:19 PM   #9
Fyrzowt's Avatar
2000 25' Safari
West of Fort Worth , Texas
Images: 8
If you haven't seen it yet, there is an older thread that someone posted to today that also deals with this problem.
Dave
http://www.airforums.com/forums/f457...tml#post508254
Fyrzowt is offline   Reply With Quote
Old 01-22-2008, 07:55 PM   #10
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
When we bought our 67, it had an electric, which, of course, bit the dust just a couple of days before our maiden voyage. I got a manual replacement -- and had one devil of a time getting the old one out. It did take some major beating to get it to move.
When you put the new one in, get yourself some new, grade 8 bolts.
Lynn
WBCCI 21043
eubank is online now   Reply With Quote
Electric tongue jack help RVnDixie All Argosy Trailers 8 12-31-2006 08:54 PM
How do I lube the tongue jack 63air Jacks, Stabilizers, Lifting and Leveling 4 06-29-2006 10:32 PM
Tongue Jack - Which one?!? SilverToy Jacks, Stabilizers, Lifting and Leveling 6 12-13-2005 10:51 PM
Tongue Jack Happycampers Jacks, Stabilizers, Lifting and Leveling 1 12-21-2004 11:01 AM
Disabling Tongue Jack Cracker Jacks, Stabilizers, Lifting and Leveling 10 11-14-2003 11:32 AM
