Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Jacks, Stabilizers, Lifting and Leveling
Old 04-11-2006, 02:25 PM   #1
Chuck
Sad Moderator
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
Remove, or Replace?
anyone got one of these?
http://www.wheelmasters.com/images/levelmaster.jpg
does it work?
got one thats been broken since before I bought the trailer, but never took it off, figuring that I'd have to fill the holes with something. Now, I've discovered a new leak up front, and I'm wondering if I should just remove the thing, and fill the holes w/ olympics, or replace it. (who knows what kind of "scar" it might have left on the underlying finish?).
seems to be made for an A/S, though...right color blue, on alluminum. hmmm....
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
Old 04-11-2006, 02:50 PM   #2
wrepete
wrepete's Avatar
Profile:  1996 28' Excella
Geneseo , New York
A Good Design
Chuck: I replaced a smaller one that came with our new AS with the one you show, and I think it is a really good design, especially easy to read when pulling into the campsite.
Bud
1996 28ft Classic
2008 Silverado Duramax 2500HD
Hensley/BrakeSmart/EnKay
wrepete is offline   Reply With Quote
Old 04-11-2006, 03:00 PM   #3
markdoane
Profile:  , Minnesota
Images: 59
Well now, that reminds me of a funny story. Maybe the level isn't broken and just needs to be adjusted properly.
How to get the trailer perfectly level
This seems a good day to describe my recommended method of perfectly levelling the trailer from side to side. I first get the trailer sufficiently level for comfort and for using the refrigerator by using one or two planks under one side. Then, I go to the large bubble level fixed across the front of the trailer, and the bubble will usually be off by an inch or so. The level is mounted with two screws through vertically slotted holes. Here is the important part - the screws are not tightened right up. This enables me to adjust the level until the bubble is exactly in the centre of the level marks. It works every time, and my dear wife and fellow campers are always impressed with the accuracy of this method. Nick.
Originally posted by Nick Crowhurst
Non-contributing deadbeat.
Old 04-11-2006, 04:49 PM   #4
Chuck
Sad Moderator
Chuck's Avatar
Images: 99
hmmm...that does make one wonder about the purpose of the silly thing.
But I assure you...this one is broke. there's no fluid in it. beyond adjusting, I dare say....
Air:291
Wbcci: 3752
'73 Safari 23'
Old 04-11-2006, 08:48 PM   #5
azflycaster
azflycaster's Avatar
Profile:  1975 25' Tradewind
Phoenix , Arizona
Images: 60
I have one. It was on my TT from the PO. I really like it. When looking for level ground I can move the trailer a little bit and see what the ground looks like. I can even judge how many lynx leveler blocks I need to make it right if I can not find a level area.
Richard
Charter Member Four Corners Unit
azflycaster is online now   Reply With Quote
Old 04-11-2006, 08:55 PM   #6
thecatsandi
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
One came with my trailer. The dealer said not to install it. Did not want to put holes in my new reailer.
Michelle
I'm not afraid I learned to drive in Washington, DC
Sarah
Ruby, (05 BMW R1200RT) serviced and put to bed for the winter
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Classic 31 w/dinette, solar)
http://Michelles-Adventures.US
Old 04-11-2006, 09:10 PM   #7
guy99
guy99's Avatar
Profile:  Dunsmuir , California
Images: 16
You could install it with exterior mounting tape. As long as you could get it off without damage to the skin.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 04-11-2006, 09:37 PM   #8
rebel beck
rebel beck's Avatar
Profile:  1975 31' Sovereign
Oxford , Mississippi
Images: 35
We really like ours, we have 2 one on the front and one on the side. They were on the trailer when we got it. They do come in handy.
Becky
rebel beck is offline   Reply With Quote
Old 04-11-2006, 10:17 PM   #9
davidz71
davidz71's Avatar
Profile:  1986 25' Sovereign
Southern Middle , Tennessee
I had one on my previous Excella 500 but after a few years the ball started to rust. They are pretty nice if you can keep the shiney ball from rusting.
Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
Old 04-12-2006, 01:44 AM   #10
clancy_boy
clancy_boy's Avatar
Profile:  2003 22' International CCD
1966 17' Caravel
Kiln , Mississippi
Images: 8
Seen them inside of an AS
I saw one of these on the inside of an AS that I was looking at post Katrina. The trailer was trashed but when I saw this post I remembered that the level bubble was over the bathroom door entrance. Seemed strange to me but I never really gave it much thought until now. Probably needs two people to level with this method.
Maybe a way to check the level of the tanks - when full the trailer tips back........
Michael and Tina BZ
1966 17' CARAVEL
2003 22' INTERNATIONAL CCD
WBCCI 30962
><((((º> ¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>
¸.·´¯`·.¸¸><((((º> ¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>¸.·´¯`·.¸¸><((((º>
Old 04-13-2006, 06:31 AM   #11
thecatsandi
Missoula , Montana
I took a two foot level and lay in insidethe door.
I can level it my self without having to go into and out of the trailer.
Michelle
Sarah
Old 04-13-2006, 08:47 AM   #12
Chuck
Sad Moderator
Chuck's Avatar
Images: 99
thats what I've been doing, but it requires multiple trips back and forth from the toungue jack, and the door.
which isn't the end of the world, of course. The more critical question revolves around the fact there there IS one of these on my trailer, which is not functioning. The holes that were created by it must be sealed to prevent further leaking. so the question is, "should I do that by replacing this unit w/ a new one, or just rip it off and fill the holes?"
Air:291
Wbcci: 3752
'73 Safari 23'
Old 04-13-2006, 08:57 AM   #13
markdoane
Images: 59
Chuck,
I think it depends on what the metal looks like under the old level. If you can make the metal match the surrounding area I would just fill the holes and let it go.
Old 04-13-2006, 08:59 AM   #14
clancy_boy
clancy_boy's Avatar
1966 17' Caravel
Kiln , Mississippi
Images: 8
OK, back to what you really wanted. What I did with unwanted screw size hole was put a rivit in the hole to plug it - using your favorite brand of sealant. The effect is the extra rivit gets lost in the sea of silver and other rivits - even though it's only plugging a hole. I have 7 of these where I removed the old TV antenna. Nobody can see them but me. They sell the Olympic rivits that match - with so few holes you can trim them with a sander or Dremel tool (what I used)
Michael and Tina BZ
1966 17' CARAVEL
WBCCI 30962
Repair or Replace Original Bowen Water Heater? Andy R Water Heaters, Filters & Pumps 8 11-16-2005 04:51 PM
need to replace a radiator cap stuart1 Mechanics Corner - Engines, Transmission & More... 1 10-28-2002 03:12 PM
Total floor replace 74Argosy24MH Repairing/Replacing Floor &/or Frame 1 06-27-2002 05:05 PM
How Do I Remove Rivets melprice General Interior Topics 1 05-31-2002 07:07 PM
Replace copper water lines in 61 Bambi 61BambiCanada Fresh Water Systems 1 05-22-2002 07:04 AM
