Old 04-28-2015, 08:15 PM   #1
Modesto , California
Rear Air Bags
Has anyone replaced the rear airbags themselves? We are trying to figure out how hard they are to replace. Is this something my husband a home mechanic can do?
Lynn
Elskedeen1 is offline   Reply With Quote
Old 04-28-2015, 08:45 PM   #2
Smartstream's Avatar
1982 28' Airstream 280
Port Angeles , Washington
It's not hard, normally 2 bolts and an air fitting on top and 1, sometimes 2 bolts on the bottom. Trouble is you can't see the top so you are working blind and it's cramped and dirty and dirt falls in your face. Use heavy jack stands to support the coach while you are under it. While you are there check the bushings in the horizontal dog bone link. Tell your husband to have fun and he will become one with the coach.
Cheers, Dan
~ Margaret Thatcher ~
Old 04-29-2015, 12:17 AM   #3
Smartstream,
Thank you, I will give this information to my husband. Would you happen to know where we can purchase the replacement airbags?
Best Regards,
Lynn
Old 04-29-2015, 01:00 AM   #4
Try here. Identifying a Firestone Air Ride Spring, Air Spring Tips | SD Truck Springs | Leaf Springs, Helper Springs and Suspension Parts It's also a good explanation of how to identify the your air spring.
Cheers, Dan
Old 04-29-2015, 11:25 PM   #5
Thank you, I will check it out.
'89 345 rear air bags have no air DENNIS HAWS Classic Motorhomes 31 04-22-2013 04:43 PM
Rear Air bags PeterH-Airstreamer Mechanics Corner - Engines, Transmission & More... 24 11-12-2007 06:02 PM
Air pressure in front air bags on LY Santart Land Yacht/Legacy Motorhomes 1 08-29-2007 09:50 PM
Air pressure for rear air bags Jon Smith Towing, Tow Vehicles & Hitches 2 08-12-2003 09:08 PM
