Old 06-24-2012, 05:50 PM   #1
2013 22' FB Sport
Hettinger , North Dakota
Questions on 2013 22' FB Sport
On the 2010-12 Airstream sport 22fb's has anyone had a problem with the dump drain scraping the ground? Is there a place for a skid be made to wrap under and protect it?
Another question is jacking it up. Is there an axle mounting plate on them where a bottle jack can be used?
The reason I am asking , I don't have it yet but will in 8 weeks.
boomerang1 is offline   Reply With Quote
Old 06-29-2012, 09:52 PM   #2
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
There is a lifting point (plate) on all airstream trailers. At that point any ack can be used. I believe it to be just behind the axle.
Do get an owner's manual and follow the instructions.
I do not know about your other issue other than take is slow when pulling over driveway to street aprons.
>>>>>>>>>>>>>Action
Old 06-30-2012, 07:15 AM   #3
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
The 2008-2012's are all the same underneath. There are four jack pads that are marked, none on the axle. The waste valves are protected by two verticle skid devices. As far as I know i've never scraped the valves.
Ahab is offline   Reply With Quote
Old 06-30-2012, 06:56 PM   #4
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
The valve plumbing on Airstreams is fairly low-slung compared to other brands of trailers...you just have to be careful when you enter driveways of gas stations, etc...take it slow and go at an angle so you are not hitting the uplift of the curb at the same time on both sides...and go slow. It has not been an issue for us.
TB & Greg and Abbey Schnauzer
#3954
