Old 08-09-2007, 08:46 PM   #1
badelson's Avatar
1969 31' Sovereign
Cogan Station , Pennsylvania
Questions about Jacking for inspection and repair
Hello everyone,
I am new here. I just registered and started reading/writing posts a few days ago.
I have a 1969 31' Sovereign and I need to get it off the ground enough to have comfortable working room. I have spent hours reading the many threads about jacking up an AS, but I guess I still need some comforting.
This is what I have gathered in simple terms:
1. Block under the "A" frame in the front
2. jack using bottle jacks between tires on the frame(jack stands after)
3. support the rear end of the trailer for stability only
So am I to assume that you can actually lift the entire camper from between the wheels on the frame? I would like to have 24" or so from ground level for good elbow room while working.
I apologize if these questions have been asked and answered a million times before, I guess I am just looking for some reassurance that this IS the proper way. I have read a few horror stories on the forums about jacking/lifting improperly.
Thanks much!
Ira
**Just cause I'm drive'in through life doesn't mean everyone else is a passenger.
4 Blogs for you to view
http://www.badelson.blogspot.com
badelson is offline   Reply With Quote
Old 08-09-2007, 08:59 PM   #2
wkerfoot's Avatar
1979 23' Safari
1954 29' Liner
Orange , California
Originally Posted by badelson
Hello everyone,
Thanks much!
I would use wood ramps to get the height that you need and leave the trailer attached to the tow vehicle.
Blll
Just my personal opinion
Old 08-09-2007, 09:15 PM   #3
badelson's Avatar
1969 31' Sovereign
See, I have to remove all of the wheels and rebuild all of the brakes, maybe more. The situation dictates that I have to do all of them at once. So, if I could lift it up and not have to set it down until all repairs are done, this would be great. As far as the other stuff, I may need to remove the belly cover a bit to inspect and posssibly repair other potential problems.
Long story, but the reality is that I need to get it off the ground for a good 1 month period and still be able to go in and out of the camper at will. I do not have the luxury to keep it hitched to my truck over that period of time. Unfortunately the camper is an hour drive away, so I have to maximize each trip.
Ira
Old 08-09-2007, 09:44 PM   #4
_
... I guess I am just looking for some reassurance that this IS the proper way. I have read a few horror stories on the forums about jacking/lifting improperly....
greeting ira
the correct answer is in this thread...
http://www.airforums.com/forums/f457...eam-18435.html
just select one
cheers
2air'
Old 08-10-2007, 08:05 AM   #5
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 202
In my not so humble opinion (IMNSHO), I would definitely use 6" x 6" lumber to achieve the working clearance you desire (may not give you 24" but I'd be really uncomfortable raising it much higher and being underneath it) but from my experience, will give you plenty of room to work and inspect. (Trust me, I've spent hours under them.).
As for rebuilding brakes on a '69 with original axles (again, speaking from experience), I cannot imagine a bigger waste of time or money. I did it once on a '72 Overlander and really wished I'd just put new axles on it (or left it alone). With the '73 Sovereign, I replaced the entire running gear, which gave me new suspension, brakes, and NeverLube hubs, not to mention brake drums with studs rather than threaded bolt holes (for my new aluminum rims).
Even with removing wheels while elevated, you can accomplish the "lift" with the 6" x 6" ramps on one axle, while using jackstands to stabilize the rest of the coach.
New axles aren't that big of a deal. I replaced mine with Dexter 3600 lb axles for less than $1000. Modifications were minimal. But it addresses a host of issues and should give another 15-20 years of service.
(3 years ago, I would have fought that advice, but after piecemeal approaches which added up $$ over time, I've finally seen the light!)
PM me if you have any questions.
PizzaChop photos
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 08-10-2007, 12:38 PM   #6
badelson's Avatar
1969 31' Sovereign
Hey, thanks for the reply.
PizzaChop, I noticed your pictures and read through your thread. Lots of good stuff there. As I said in my original post, I realize that these questions have been answered many times before. Yet, for some reason I was still unsettled about the idea of bending or contorting the old girl and causing serious damage. I have plenty of experience in jacking and cribbing buildings, so the safety of what I need to do is a factor, but I believe that I can do it without too much trouble. I will create a good solid footing to crib upon.
As for the axles, well, I would like to drop the G and get new ones, but if I can safely rebuild things, that would be best as far as my budget is concerned. I need to get this camper to Pennsylvania, 8 hours away. After that, she sits for a few years until the time comes to completely restore her. If things look to be in bad shape, I will follow your advice.
I'll post some pics on Monday if I manage to get it jacked up.
Thanks again!
Ira
Least expensive repair thenewkid64 General Repair Forum 5 09-23-2013 08:49 AM
Dash Repair Questions JW84345 Airstream Motorhome Forums 15 07-15-2012 08:59 PM
Bed Glide Repair Tamara General Interior Topics 16 08-31-2006 08:28 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
airstream repair halloey General Interior Topics 3 07-27-2002 06:48 PM
