Old 08-25-2014, 02:01 PM   #1
Lothlorian's Avatar
Loganville , Georgia
Putting 1973 stabilizer jacks on a 1960
I have 4 1973 stabilizer jacks from a scrapped Airstream. I want to put them on my 1960 Overlander. Has anybody done this? I found a thread a couple of years ago posted on how to do it, but now I cannot find it. The thread if I remember correctly said get a big magnet and run it on the underbelly to find a cross member to anchor the stabilizer into. I remember the thread reading you could not anchor them like they were on the 1973. Any advice would be appreciated.
Brian
Brian & Adrienne
Lothlorian is offline   Reply With Quote
Old 08-25-2014, 03:15 PM   #2
Brian
Brian.
You don't need a magnet.
Simply look for the rivet line, that's between the main frame. It will go from one side of the trailer to the other side, but only between the main frame.
The "T" part mounts to the main frame and the bottom of the "T" mounts to a "cross member".
It's that easy.
But use at least # 10 screws.
Old 08-25-2014, 04:52 PM   #3
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
How wide are the frame rails you will be attaching into? I would like to do the same thing to my trailer. Please post pics if you do it, I would love to see how it works out for you.
Stephanie
Old 08-25-2014, 05:19 PM   #4
Steph.
The axle mounting dimension is 57 7/8 inches, which is outside of frame to outside of frame.
Old 08-25-2014, 05:42 PM   #5
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
I guess going from the mounting plates on the axle it shouldn't be too hard to find the correct spot to mount the stabilizers behind the rear wheels?
Stephanie
Old 08-25-2014, 05:53 PM   #6
Central , Mississippi
... I found a thread a couple of years ago posted on how to do it, but now I cannot find it....
Brian
Here is where we discussed it
http://www.airforums.com/forums/f109...ml#post1066463
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 08-25-2014, 07:16 PM   #7
Lothlorian's Avatar
Thanks Guys:
I am going to pursue this. Thanks a bunch. HI you trailer looks awesome!
Brian
Brian & Adrienne
Screwy Stabilizer Jacks kavosCCD Jacks, Stabilizers, Lifting and Leveling 10 08-15-2010 11:11 PM
Stabilizer Jacks--what should we get? Laure&Chuck Jacks, Stabilizers, Lifting and Leveling 12 11-15-2005 04:07 PM
frozen stabilizer jacks silver suz Jacks, Stabilizers, Lifting and Leveling 10 03-24-2004 10:12 PM
How many stabilizer jacks are standard? Janet H All Argosy Trailers 3 03-13-2004 10:09 PM
