Old 02-04-2013, 07:17 PM   #1
1984 31' Excella
Annapolis , Maryland
Powering lift jack from my Jeep
Our 31-ft '84 excella has been sitting in one spot for a long time and we need to lift the power jack in order to move it. My question is -- if we connect hte 7-way power cord from the trailoer to the tow vehicle (a 2001 jeep), will that provide enough power to life the jack?
Joy Quill is offline   Reply With Quote
Old 02-04-2013, 08:12 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
It is a 12 Volt DC jack, that is what your Jeep should be putting out if the plug is correctly wired.
MICHAEL
Old 02-04-2013, 09:09 PM   #3
1974 Argosy 20
Kooskia , Idaho
The Jeep charge line has a circuit breaker (or maybe a fuse) which will limit the power that can go through the charge line. It may or may not have the necessary amp capacity to run the jack. The only way to tell is to try it.
If you still have the battery and converter/charger in the AS, it should run the power jack just fine. Even without the battery, the converter/charger will have capacity enough if it is plugged in to 120 volt power.
Old 02-04-2013, 10:32 PM   #4
Protohyp's Avatar
1977 31' Excella 500
Los angeles , California
Send a message via AIM to Protohyp
Question is WHY has it been sitting in one place for so long?!
Protohyp is offline   Reply With Quote
Old 02-04-2013, 10:52 PM   #5
mefly2's Avatar
2015 25' FB Eddie Bauer
Wouldn't try it as the load from the jack motor likely exceeds the wiring to plug / receptacle ... you might be able to sneak it by once or twice, but my guess is that it will blow the fuse - as the voltage goes down, current requirement goes up.
Old 02-05-2013, 12:06 PM   #6
Wise Elder
Jammer's Avatar
2010 30' Classic
It depends, and the only way to find out for sure is to try it.
If the 7-way is wired properly at the Jeep and trailer then the charge line should be at least 10 gauge wire and should be fused for at least 30 amps -- more than enough to run the tongue jack, assuming that it's properly oiled or greased. But it's not unusual for the charge line to either be disconnected or not working. Most people don't check, and a few manufacturers (but not Dodge or Jeep as far as I know) leave it disconnected from the factory.
I would suggest bringing the crank along, or maybe an extra already-charged battery that you can install in the trailer.
Old 02-05-2013, 12:40 PM   #7
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
If you're not sure, use the hand crank.
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 02-05-2013, 12:42 PM   #8
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
If there is no battery in the trailer, check that the positive cable for the battery is not touching anything metal or you will blow a fuse, as the truck line will put power to that cable
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
98 Safari
1950 Spartan
1966 Globetrotter
Shacksman is offline   Reply With Quote
Old 02-05-2013, 01:39 PM   #9
1982 34' Limited
Harrowsmith , Ontario
I've done that on mine successfully with no issue - just do as Shacksman suggests and make sure the positive cable for the battery is safe.
BradB is offline   Reply With Quote
Old 02-05-2013, 01:40 PM   #10
1988 32' Excella
Robbinsville , New Jersey
If you are taking the trailer on the road you should have a battery for the break away switch to be safe and legal.
Old 02-05-2013, 04:58 PM   #11
1984 31' Excella
Thanks to all of you for this helpful advice. My husband is still considering the best way to proceed. He asked me to post another question -- it's about the big 3-prong power cable that comes out of the rear of the trailer. Is there an adapter that would allow us to connect with a regular extension cord, which we could plug into household current?
The reason we haven't moved the trailer for a while is that we use the airstream as overnight accommodations for guess. They enjoy and everyone still has privacy.
thanks to everyone for your help. We really appreciate your advice and guidance!
Joy
Old 02-05-2013, 05:29 PM   #12
AWCHIEF's Avatar
Images: 33
Joy, you should be able to get a 30 or 50 amp (depending on what you have) to 15 amp adapter at any Walmart or RV/trailer/auto parts store.
MICHAEL
Old 02-05-2013, 05:37 PM   #13
1973 29' Ambassador
Seattle , Washington
Hi Joy,
Yes, there is an inexpensive adapter that will let you plug that three prong into a regular extension cord. Please note that you MUST open the batter box, make sure the battery is OK (or disconnect it and make sure the batter wires aren't touching anything) and then plug in the power. You are probably looking for something like this thing, but any local RV shop as well as wal mart, home depot, etc should have them for you. Amazon.com: Conntek 15 Amp Male Plug To 30 Amp RV Female Connector RV Adapter: Sports & Outdoors
dcheshire is offline   Reply With Quote
Interesting Tongue Jack electrical problem Wingeezer Jacks, Stabilizers, Lifting and Leveling 15 10-12-2012 10:08 PM
OK to use a jack instead of blocks to level? KYAirstream Jacks, Stabilizers, Lifting and Leveling 27 09-18-2012 06:42 AM
Jack & Lug nut wrench Tim_S Tires 41 10-31-2011 08:27 AM
Vintage Tongue Jack - Reese IndyAnne Jacks, Stabilizers, Lifting and Leveling 11 10-19-2011 01:32 PM
Lift Jack ThreeFingers Hitches, Couplers & Balls 4 09-20-2011 10:50 AM
