Old 03-16-2009, 08:58 AM   #1
1972 29' Ambassador
Morris , Indiana
Power Jack - what size?
I have a 72 AS. I am tired of jacking maually. Plan on putting a power jack in. What size and brand? Also where can I get power?
Dona is offline   Reply With Quote
Old 03-16-2009, 10:05 AM   #2
DanB's Avatar
1970 23' Safari
2005 30' Classic
1986 31' Sovereign
Lorain , Ohio
Hi Dona,
My trailer original had one, but I cooked it. I really miss it. Its a nice luxuary!
I was planning on replacing it with a camping world one. Biggest concern was noise. My old one sounded like a cross between a smoke alarm and a cat being run over.
Whatever you get, be sure it has an easy to get to manual crank.
DanB
________________________________
Proud Member of the Wally Byam Airstream Club #24260
www.campnova.com
The “Ohio Airstreamer -- Informal forum for weekend camping” thread.
DanB is offline   Reply With Quote
Old 03-16-2009, 10:35 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
While just about any jack will handle your trailer the important consideration is the weight of your TV. If you are using a WD hitch you will want a jack that can lift the trailer/TV combination enough to hitch the WD. With at in mind go for the 3,500 lb. jack.
2004 Excursion 4x4
Old 03-16-2009, 01:08 PM   #4
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Ditto on just about any jack will work I have a 3500# Atwood. Your tongue weight is about 500#.
I have a Reese WD hitch, but I am confused about the statement "lift the trailer/TV combination". I have never done that. I just use the pipe/ lever supplied to tension the bars.
Old 03-16-2009, 01:50 PM   #5
HowieE's Avatar
Images: 12
If you do not have to lift the TV and trailer to hook up your hitch my first guess would be your WD hitch is not doing it's job because it is not set up correctly.
The purpose of a WD hitch is to transfer weight to the front axle of the TV and to the trailer axles. If you can pull the chains up without reducing the load on the bars by lifting the combination I doubt you are transferring any weight for and aft.
2004 Excursion 4x4
Old 03-16-2009, 02:34 PM   #6
Silverwanabe's Avatar
1967 26' Overlander
Winston Salem , North Carolina
Images: 107
I added a Barker jack to mine unit from Camping World.
BTW, water was getting into the head of the first one.
It was replaced with a new jack under warranty.
I wanted a Super Jack, but an H & H would have cost too much.
Here's a helpful link.
Power Jacks
Greg
Winston Salem, NC
WBCCI 5218,
Corresponding Secretary Piedmont NC Unit 161,
1967 Overlander International.
1979 Avion 30ft rear bath
TV's 88 Chevy Suburban 454, 3:42, TH400
95 Cadillac FW Brougham, LT1,3:42, 7k tow pk.
Silverwanabe is offline   Reply With Quote
Old 03-16-2009, 08:39 PM   #7
Lumatic's Avatar
1993 34' Excella
Images: 16
My set up for the hitch has largely been trial and error. I have read some pretty techy instructions on setting up the hitch which gave me brain strain. I also experimented with measuring the distance between the tire and fender with the hitch loaded and unloaded and also having the trailer and TV sit in a level line.
Now I could be, and maybe am wrong, but my hitch came with a pipe a little more than a foot long that slips over a post on each bracket on the A frame to tension the chains and the bars. It seems to me I can get more than enough weight transfer by using this lever. If I understand you correctly you hook the trailer to the ball, then use your tongue jack to raise both the tongue and rear of the TV then hook up your bars. As far as I figure it tensioning the chains using this lever does the same thing as jacking up the whole hitch/ tongue and then hooking up the chains/bars.
Am I missing something here? please let me know.
Old 03-17-2009, 08:45 AM   #8
HowieE's Avatar
Images: 12
Setting up a Reese Dual Cam system is not a 5 min. job. I have taken as long a 4 hours of adjusting to get it right on some trailer TV combination.
Read through this thread and you will get a better answer as to what you are attempting to achieve when setting one up.
http://www.airforums.com/forums/f464...-it-46606.html
When I hitch my 34 fter to my Excursion I have to lift the ball almost 3 in. from the dry loaded position in order to pull up the chains and I am using an 18 in. pipe to lift the chains. Now this is not to say you will have to jack your rig this high because it is a smaller and lighter trailer.
If you go back and use the fender drop method for set up put a small piece of masking tape on the fender and mark a point on the tape while the trailer is not hooked up and compare that to when the trailer is hookup up. You are only looking for about a 3/8 in. to 1/2 in. change at the front axle so the makers give you a better shot at it.
Keep in mind as you adjust the head angle to get the correct weight transfer on the hitch you have to readjust the position of the U bolts holding the arms so the bars sit in the saddles correctly.
2004 Excursion 4x4
Old 03-17-2009, 09:05 AM   #9
Lumatic's Avatar
1993 34' Excella
Images: 16
My hitch is not a dual cam. My head angle is not adjustable. The head is welded on. Seems to tow fine. They say ignorance is bliss.
I can see using the jack with a 34 footer or newer AS with a higher tongue weight than my 25 foot 71, about 500#. My 73 Sovereign also had a tongue weight of about 500#.
Old 03-17-2009, 09:29 AM   #10
HowieE's Avatar
Images: 12
That is what they say, but not something to be proud of.
2004 Excursion 4x4
Bolt size for new mechanical jack? toddingalls Jacks, Stabilizers, Lifting and Leveling 5 12-14-2008 03:34 PM
power to my jack bill long Jacks, Stabilizers, Lifting and Leveling 6 11-25-2007 09:44 AM
power jack crowbar68 Jacks, Stabilizers, Lifting and Leveling 2 04-30-2006 11:22 PM
Power Jack Breaker Size Rick Alston Electrical - Systems, Generators, Batteries & Solar 4 08-31-2004 12:46 PM
power jack Tikihut Jacks, Stabilizers, Lifting and Leveling 3 03-20-2003 07:12 PM
