Old 09-18-2017, 11:33 AM   #1
Mountain Home , Arkansas
Power jack quit working
It has been working fine. The PO had some Jerry rigged wiring around the jack and safety disconnect, but connecting a battery to two wires at the jack would operate it. Now it's just dead. I have a crank, but would like the jack to work of course. Any troubleshooting tips? Also, if everything is wired correctly would the jack run off on board battery or TV connection?
Scotty033x is offline   Reply With Quote
Old 09-18-2017, 11:45 AM   #2
2016 30' International
Florence , Alabama
Should be a fuse somewhere to protect things.
If wired correctly the TV should charge the onboard battery; but I'd rather have the current capacity of the onboard battery and not rely solely on the TV connection.
joshjack is offline   Reply With Quote
Old 09-18-2017, 02:16 PM   #3
paiceman's Avatar
Upper St Clair, PA/Titusville, FL , PA-Summer/FL-Winter
Have you run a line check to see if it's getting current? As Josh said there should be an inline fuse and it should be wired directly to the battery.
SAFE TRAVELS
Bud
2017 30' Classic - F350 6.7 Diesel Crew
USAF - Military Training Instructor (TI) - 68-72
Old 09-18-2017, 03:06 PM   #4
Fuil-Timers
DreamStreamr's Avatar
2005 25' International CCD
Everywhere , North America
Images: 38
Send a message via Skype™ to DreamStreamr
Like Josh and Paiceman say, check fuse first 'cause it's easiest. Our fuse (2005 Airstream with Barker 3000 jack) was in an inline holder, bright yellow, on the jack end of the wire. The other end of the wire goes into the battery box and connects directly to the positive post of the battery. The negative or ground connection is solely through the bolted flange connecting the jack to the A-frame.
I've seen one other configuration, where either the factory or someone afterward installed a automatic resetting 30a circuit breaker just outside the battery box, then the 10 gauge wire runs to the jack. So if you don't find an inline fuse, or if you do and it's good, then check voltage between the fused wire and ground. If no voltage then look for another fuse or circuit breaker between that point and the battery. But if voltage is okay to the inline fuse, then need to check voltage at the terminal strip in the jack's head cover.
If power all the way to the jack's terminal strip, then I'd check the limit switches and hope one of them is holding it out.
Okay, I'm out of ideas and going back under the trailer to fix the leaking fresh water tank drain valve. Again. . .
Chasing 75 Degrees,
Jim N5RTG
dreamstreamr.com
dreamstreamr.wordpress.com
DreamStreamr is offline   Reply With Quote
Old 09-18-2017, 04:42 PM   #5
Goal15's Avatar
Holly Lake Ranch , Texas
If it is the fuse and it keeps blowing, look at the wire that goes to the battery box. It often runs under the propane tank cover on a plastic flexible wire cover. Ours had rubbed through the wire cover and into the wire causing a short. Insulated the wire and no more problems.
Dana
Dana and Olga
2006 Safari 23
2011 Tundra Double Cab
Goal15 is offline   Reply With Quote
Old 09-18-2017, 07:35 PM   #6
dmbecke's Avatar
2014 25' FB Flying Cloud
Des Peres , Missouri
It runs off your rv batteries. Many jack issues are related to a poor ground
Find where it's grounded to trailer and scrub that ground and reattach
dmbecke is offline   Reply With Quote
Old 09-19-2017, 09:54 AM   #7
The wires were cut at the jack by PO. I currently connect a battery with alligator clips directly to those wires to operate so no inline fuse and it's getting juice. Just for some reason it quit working.
Old 09-19-2017, 10:10 AM   #8
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
What brand of power jack? Are you saying there is no response at all when you switch on the jack? In addition to the inline fuse there are microswitches in the jack head that are prone to burn out. The jack should be wired to the on board battery as is the safety breakaway disconnect. Why did the PO cut the wires?
Old 09-19-2017, 11:30 AM   #9
fwjumper's Avatar
1998 34' Limited
Lawrenceville , Georgia
How old is it? Does the light work? (If it has one)
Make of the jack?
fwjumper is offline   Reply With Quote
Old 09-19-2017, 12:34 PM   #10
Richard
2006 30' Classic S/O
Merced , California
All the above first, then push switch up or down and at the same time to one side or the other. If anything happens bad switch. Also could be one of the micro switches used to limit travel. And lastly bad switch. Best advice from above. See if the light works. If yes you need to take it apart.
kleimanr is offline   Reply With Quote
Old 09-19-2017, 12:41 PM   #11
rvb
rvb's Avatar
1977 Argosy 28
Euless , Texas
Check to see if you have juice on the jack end of you jumpers after hooking up to the battery.
Also check the battery cable connections. Our Minuet had a new battery installed a year earlier (by an RV dealer) and the terminals looked fine but the tongue jack would work when hooked to shore power and half the time not work when on battery. I finally pulled the cables off to clean them and the positive was so oxidized it was black and so loose I could just twist it and pull it off. After cleaning the terminals and bolting it on correctly it works fine.
Another thing to check if the wiring has been messed with is the emergency braked actuator on the tongue is usually wired to the 30A circuit that also goes to the jack. Check power to it. If there if no juice to it you have no emergency brakes.
President, Vintage Airstream Club, WBCCI # 7291
1977 Argosy 28 Center Bath, 1978 Argosy Minuet 6.0
2013 Toyota Tundra
rvb is offline   Reply With Quote
Old 09-19-2017, 01:21 PM   #12
albuquerque , New Mexico
Jack quit working
I learned a long time ago, fix it right the first time and be done with it !
splintair is offline   Reply With Quote
Old 09-19-2017, 03:02 PM   #13
2015 23' FB Flying Cloud
Redmond , Washington
The fuse must be a 30 amp "slow blow" fuse, otherwise it goes out often. They are a little difficult to find. NAPA had them last I checked.
D2
"Having differences makes a difference"
WestieHouse is offline   Reply With Quote
Old 09-19-2017, 03:05 PM   #14
Also, Barker folks were very helpful when I blew out a limit switch. They sent me one and I replaced it within an hour.
Fortunately, I was pleased with how easy the manual jack worked while waiting for the switch to arrive at our next camp site.
D2
Emergency Trailer Brake Quit Working AustinAir Brakes & Brake Controllers 3 01-17-2009 08:23 AM
New Shurflo pump quit working? Lothlorian Water Heaters, Filters & Pumps 9 12-14-2008 06:08 AM
DC quit working in my new 64 Globetrotter GlobeTrottin Batteries, Univolts, Converters & Inverters 11 09-06-2007 08:06 PM
'96 LY fridge quit working airstream96 Land Yacht/Legacy Motorhomes 5 07-02-2007 09:05 PM
The ol' Dometic quit working... InsideOut Refrigerators 5 08-09-2004 05:07 PM
