Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Running Gear - Axles, Brakes, Wheels & Tires > Jacks, Stabilizers, Lifting and Leveling
Old 10-11-2002, 05:08 PM   #1
68 Suburban
68 Suburban's Avatar
Profile:
Power Jack Question
I am getting ready to tow the 68 Avion I purchased. I noticed there is only one wire to hook up for the power jack. Is this correct?
68 Suburban is offline   Reply With Quote
Old 10-11-2002, 05:28 PM   #2
Rickk48
Rickk48's Avatar
Profile:
Mine has two. Not an electrician, but it seems to me you would always have to have a positive and a ground.
Rick Klein
'01 Bambi
'99 Land Rover Disco
Rickk48 is offline   Reply With Quote
Old 10-11-2002, 06:00 PM   #3
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
Power jack
The power jack on my last trailer had just one wire. The ground return is through the trailer frame. Make sure you have lock nuts under the bolt head, where the jack is bolted into the tongue, so that you have a decent ground connecion..
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Pahaska is online now   Reply With Quote
Old 10-11-2002, 06:05 PM   #4
FrankR
Profile:
Power jack operation
The power jack isunder a very heavy load and requires all the good 12 dc voltage possible. If the batteries that supply voltage to the jack are down in voltage just a bit, the jack may be destroyed.
Low voltage yeilds hi amps. Hi amps is lots of heat. Hi heat eats wires.
Yep, just one slow heavy lift. A few RV people have made some wiring changes that allows the tow vehicle to power the jack and do so with the engine running. All electrical devices require 2 conductors, like the ying and yang of things. In many cases the trailer frame is the ground connection. This is not the best method, but it is quick and cheap. Good repair price for power jack motor...$110...
Visit Idaho The people are great
FrankR is offline   Reply With Quote
Question on power jack Alex Electrical - Systems, Generators, Batteries & Solar 7 12-01-2003 11:18 AM
Electric/Manual Jack Security Question docbluedevil Towing, Tow Vehicles & Hitches 1 11-01-2003 11:50 PM
Best deal on a power jack? drboyd Jacks, Stabilizers, Lifting and Leveling 1 09-10-2003 07:40 PM
Another Power Jack Question. 68 Suburban Jacks, Stabilizers, Lifting and Leveling 3 10-15-2002 10:23 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 01:51 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
Interference - U2, Pop Culture & Social Responsibility
