Old 07-26-2013, 06:32 PM   #1
RAH
2013 30' Flying Cloud
Cincinnati , Ohio
Power Jack Problem
I hate when one problem leads to another. When fixing a flat tire 2 weeks ago, the power jack stopped working in the up direction. Down worked fine. Used the manual jack to finish the tire change. Then called Barker and they sent a new switch and 2 micro-switches (no charge). When I changed the switch today, it was clear what was wrong with the old one - Connection #1 was broke off the switch - picture below.
Question: Do I really need to re-synchronize the jack? I can't quite figure it out. For one I don't know why the manual and electric parts would be out of sync - I never removed the jack head, just replaced the switch. I also can't follow the re-synch directions because the first thing is to lower the jack all the way - and then the tongue will be resting on the hensley bars and I don't want to do that I think. Jack seems to work fine both directions. Any ideas on whether re-syncing is needed?
Name:	Jack switch_old.jpg
RAH is offline   Reply With Quote
Old 07-26-2013, 07:04 PM   #2
Roadtoaster's Avatar
2015 30' Flying Cloud
Byhalia , Mississippi
I'm no expert but assuming you removed the head but DID NOT engage the up or down switch while the head was off, I think you are fine.
Greg
Roadtoaster is offline   Reply With Quote
Old 07-26-2013, 07:05 PM   #3
I re-read and noticed you did not remove the head. Seems to me you are good to go.
Greg
Old 07-26-2013, 07:19 PM   #4
HowieE's Avatar
Princeton , New Jersey
Images: 12
If you have not moved the gears, thus changing the relationship to the end switches, and have not removed the head from the post you should be fine
2004 Excursion 4x4
Old 07-26-2013, 07:52 PM   #5
airdreamers's Avatar
2008 28' International
Venice , Florida
Images: 14
I agree with the above responses. Welcome to the deflective micro switch club.
Bill and Janice, We're lovin' it! (Airstreaming)
Airdreamers
WBCCI #8880
AIR #41310
airdreamers is offline   Reply With Quote
Old 07-26-2013, 10:16 PM   #6
drew05's Avatar
2011 25' FB Flying Cloud
Peculiar , Missouri
Is this a common failure? If so can it be avoided?
Drew
drew05 is offline   Reply With Quote
