Old 05-22-2017, 12:20 PM   #1
1976 29' Ambassador
Atlanta , Georgia
Power Jack pipe replacement
Short story, I bent it and had to cut the bottom 8" or so to unmount it. The motor and the gear still work, and I was using the stubby pipe until I replaced the whole jack. I really like the look of the old Power Jack, although the new one is smoother and stronger, so I want to switch back. Any idea on where to source a new pipe? Should I have one fabricated? Thank you.
Chae is offline   Reply With Quote
Old 05-22-2017, 01:41 PM   #2
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Have you tried the manufacturer. They are usually a good place for replacement parts in my experience.
MICHAEL
Old 05-23-2017, 10:44 AM   #3
2007 27' Classic FB
Ridgefield , Washington
Images: 11
Ditto what AWCHIEF said. Barkers service is very good. If you need to replace it they still sell the jack you have and it will set you back a little over $300.
John
Woosch is offline   Reply With Quote
Old 05-27-2017, 09:33 AM   #4
PopHetzler
Emh142's Avatar
2003 34' Classic S/O
Troy , Ohio
Call Barker. They can get you a 3500# blemished return for around $75.
Emh142 is offline   Reply With Quote
New Dexter axles lack trailer braking power krohnjs Brakes & Brake Controllers 18 09-17-2013 10:02 AM
Friction.... or lack thereof JDL Off Topic Forum 4 01-19-2007 09:00 AM
Chat CANCELLED! Lack of interest! markdoane Off Topic Forum 1 05-23-2006 06:04 PM
Brakes.....or lack of. freeofecho Brakes & Brake Controllers 15 03-27-2006 08:58 AM
lack t v reception.... norbert Our Community 1 09-02-2003 09:05 AM
