Old 01-09-2010, 06:24 PM   #1
JimW's Avatar
1997 30' Limited
Omaha , Nebraska
Power Jack only goes up!
This jack is the regular Barker jack and not the Super Jack. It worked fine when I delivered the unit to JC for some new segments and had them do the 27 point inspection. I picked up the unit last Wednesday on a really nasty day. The jack lifted the tongue nicely, but balked at lowering it. After a couple of attempts pushing the toggle switch down, it seemed to "catch" and worked fine for the rest of the hitching sequence.
Today, I decided to disconnect in order to get the free breakfast buffett at the Vicksburg, MS Ameristar. I jacked the tongue up while still attached to the truck and released the spring bars, then pressed the toggle down and nothing happened. I ended up attaching a 7/16ths socket to the 18v drill and lowered the tongue manually. We did make to the buffett, but just barely.
I faintly recall installing one of these on my SOB and there was something about a limiter switch. I don't have the documentation with me, and the Barker website offers only part schematics and no details. I do know that they greased the gears at JC, which I believe requires removing the head.
Any Ideas out there on how to get this to working?
JIM
Rig: '97 30' Limited
Towed by: '13 Silverado 2500 Duramax
WBCCI #22116
JimW is offline   Reply With Quote
Old 01-09-2010, 06:55 PM   #2
garry's Avatar
1969 31' Sovereign
Broken Arrow , Oklahoma
The switch reverses the plus and minus 12V to the jack motor.
Good chance the switch has a loose or bad connection failing to reverse the motor or the switch has gone bad.
Garry
Old 01-09-2010, 08:41 PM   #3
My Grandparents Airstream
Andrew Selking's Avatar
2007 28' Safari SE
Hillsboro , Texas
Send a message via AIM to Andrew Selking
The Baker jack has two micro switches on the top under the cover. I had the same problem one of the switches died. Call Baker and they will usually ship you one for free.
They stand behind their products.
Andrew Selking
WBCCI #6062
International 3rd Vice President
"Airstream the Best trailer ever built."
Andrew Selking is offline   Reply With Quote
Old 01-10-2010, 10:14 AM   #4
richinny's Avatar
2011 34' Classic
reversing the power leads might make the up switch the down switch. does anyone know if this will work or do harm to anything?
Ricky
Old 01-11-2010, 06:03 PM   #5
2007 28' Safari SE
Hillsboro , Texas
Yes it will work. I did that on mine so I could use the jack until I got a new switch.
Andrew Selking
WBCCI #6062
Power Jack Fuses SilverGate Jacks, Stabilizers, Lifting and Leveling 41 04-01-2014 07:45 AM
power to my jack bill long Jacks, Stabilizers, Lifting and Leveling 6 11-25-2007 08:44 AM
Power Jack Repair DanB Jacks, Stabilizers, Lifting and Leveling 4 07-31-2007 09:01 AM
power jack crowbar68 Jacks, Stabilizers, Lifting and Leveling 2 04-30-2006 10:22 PM
power jack Tikihut Jacks, Stabilizers, Lifting and Leveling 3 03-20-2003 06:12 PM
