Old 08-01-2019, 06:42 AM   #1
2017 27' International
Antes Fort , Pennsylvania
Power Jack not working
The 30 amp fuse was bad so it was replaced. Now the jack light works, but the power jack still doesn't work. I believe the fuse blew because the wire from the battery had been crushed by the propane tank cover when it was put on and tightened. The wire has been wrapped with electrical tape. A multimeter shows power going into the jack motor. Any hints?
alphamale49 is offline   Reply With Quote
Old 08-01-2019, 06:47 AM   #2
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
A typical problem is bad ground since this thing gets its ground through the base plate to the A-frame. Gets rusty and will conduct enough for light but not for motor. Got to disassemble and clean/lubricate.
Larry
lsbrodsky is offline   Reply With Quote
Old 08-01-2019, 08:23 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
If it was an open ground the light would not light. Wooden hurt to tighten the 3 bolts that mount the jack to the tongue.
If it is not blowing the fuse now it is not a locked rotor in the motor. I would open the jack and test for voltage going into the limit switch assembly. If you do not find voltage there the wire leading to the jack is open. If there is voltage to the switches apply voltage directly to the motor leads bypassing the limit switches. Do this with both polarities to the motor to make sure the jack is just not jammed against one of the stops.
If the motor works and you had voltage to the limit switched set the jack shaft with the hand tool originally supplied with the jack to make sure the shaft is at least 1 1/2 turns off the limit of the lead screw in the shaft. If the shaft is set correctly try the motor again.
If the motor did not work when test as a stand alone the motor has opened.
2004 Excursion 4x4
Old 08-01-2019, 11:26 AM   #4
We removed the jack and filed down the surfaces to make a ground contact. Still not working. Would like to try and power directly to the motor. I don't know what a 'limit switch' is. Is that the up and down switch?
Old 08-01-2019, 11:36 AM   #5
HowieE's Avatar
Images: 12
When you open the motor up you will find 2 switches. They are the limit switches. One reacts to jack extension and the other to retraction. They protect the motor and fuse from overload.
You should be able to distinguish the wire feeding the motor. Some motors may ground directly to the jack metal frame and some may have a ground wire fastened to the jack metal frame.
The top end of the lead screw for the jack should have a slot at the top that is used to manually use the jack when the motor fails in the field. That is the adjustment I mentioned to set the limit on the lead screw. You should not have to readjust the lead screw if the jack was working before this problem as it was set at the factory.
2004 Excursion 4x4
Old 08-01-2019, 11:48 AM   #6
Rivet Puller
SeeMore's Avatar
2003 28' Safari S/O
Atlanta Burbs , Georgia
If the prior responses aren't sufficient or unclear, you might want to try finding a video clip on YouTube for a visual walk through all the issues/items mentioned. Enter "electric tongue jack troubleshooting" and you will be surprised by with the lengthy list generated.
Sir Tristan
Air #48582, S/SO #003, WBCCI #4584
SeeMore is offline   Reply With Quote
Old 08-01-2019, 12:24 PM   #7
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
When we had a similar issue, it turned out to be a bad toggle switch, which was an easy fix. Joe
jayseejay is offline   Reply With Quote
Old 08-02-2019, 09:32 AM   #8
Silver Star
rucos's Avatar
1970 23' Safari
Victoria , British Columbia
Ive had to replace my toggle switch due to corrosion twice in the last 5 years. After the last time I now have a nice water proof cover that I use while storing or sitting.
rucos is offline   Reply With Quote
Old 08-02-2019, 10:49 AM   #9
Thanks everybody. I have an appointment to fix with an Airstream dealer. Glad I bought the 7 year extended warranty plan. Seems like after three years problems start. Power Jack won't work, dead bolt won't work, steps are broken, drawer next to door under seat is falling apart, converter wen't bad.
Old 08-02-2019, 06:37 PM   #10
2019 25' International
Washington , Washington, D.C.
rucos - about that water proof cover on your jack. Did you buy it? If yes, where? Thanks!
PatLee is offline   Reply With Quote
Old 08-02-2019, 06:48 PM   #11
rucos - never mind - I just went to Amazon and bought an awesome LCI jack cover that does everything except tuck me in at night.
Shore power and gen power not working merrillv Flat-Front (Cutter, Clipper, XC, XL & Skydeck) Motorhomes 5 03-14-2019 09:46 AM
Electic Jack not working - fuse good - manual not working ryandanz Jacks, Stabilizers, Lifting and Leveling 20 04-24-2016 10:04 AM
Power Jack not working. AWCHIEF Jacks, Stabilizers, Lifting and Leveling 15 08-12-2014 07:19 PM
Power Jack/Control panel not working TinLiz Towing, Tow Vehicles & Hitches 5 06-27-2012 11:41 AM
Power Jack isn't working jnerges Jacks, Stabilizers, Lifting and Leveling 4 03-23-2008 07:25 PM
