12-30-2014, 04:39 PM
2013 30' International
asheville
, North Carolina
Power jack is stuck
Looking for some help…
My power jack for my 2013 International is giving me fits. Yesterday it churned slowly, then died completely. Fuse was good. I pulled the compass to reach the lug to raise it manually, then attached the metal crank…got shocked and the fuse blew…hmmm. Replaced the fuse, tried the switch. It did a 1/10 turn, froze and blew the fuse. I disconnected power and tried the manual crank again. It will not turn at all. I opened up the head and disengaged the motor from gears then powered up…motor runs fine. So I am guessing at something in the stanchion for the pedestal. But I literally cannot turn anything. And I can't get the gear/lug out to work on it (see picture…I can't seem to get any farther).
And suggestions before I give up and buy a new unit?
12-30-2014, 04:58 PM
2014 27' FB Eddie Bauer
Chelsea
, Michigan
Just guessing here, but I wonder if lubricating the moving parts in the jack assembly (i.e., not the motor which you have proven works) would free them up to move? The fact that you are blowing the fuse when under load makes me think that there is a jam in the mechanical parts of the jack.
I would try Boeshield T-9 it's what I use on most of the AS' moving parts.
http://www.amazon.com/Boeshield-T-9-...ords=boeshield
You might find this in a good hardware store or possibly a high-end bicycling store in case you don't want to wait for Amazon.
Best of luck.
Bob Martel
WBCCI# 5766
12-30-2014, 04:59 PM
2011 25' FB Flying Cloud
Anywhere &
, Everywhere
Are you still under warranty?
12-30-2014, 05:37 PM
2000 25' Safari
Davidson County
, NC Highlands County, FL
Could be the trailer rolled slightly putting the tongue jack in a bind. Try lifting the tongue just enough to take the load off tongue jack using a different jack.
Alan
12-30-2014, 05:56 PM
asheville
, North Carolina
nope
asheville
, North Carolina
tried the lube…no luck. thanks, though.
12-30-2014, 05:57 PM
Chelsea
, Michigan
I like Alan's suggestion. Try that first!
Bob Martel
WBCCI# 5766
12-30-2014, 06:00 PM
Chelsea
, Michigan
Well, then if Alan's suggestion doesn't work, I'd say it's time for a new jack. You should be able to get one for $200 to $300 plus installation.
Bob Martel
WBCCI# 5766
12-30-2014, 07:09 PM
2000 25' Safari
Davidson County
Before spending the $. From beneath the jack, look upward where the jack shaft disappears into the tube as the foot is retracted. If it is touching on one side or the other, the shaft could be bent/jammed. If it is, you might be able to dislodge it by whacking on the foot plate with a piece of wood (a 2x4) enough to bend it slightly in the opposite direction. If you can get it down, then you can use more appropriate tools to straighten it.
I had this happen when someone backed into my trailer tongue while it was in storage. I was able to straighten the shaft and get it working again.
Alan
12-30-2014, 07:19 PM
2005 30' Classic
Burlington
, Ontario
I had something similar happen when my previous SOB trailer was parked in storage - the storage company had need to move the trailer and did so by lifting the tongue with a hydraulic gadget on a tractor then moving the trailer with the tongue jack still extended.
When the placed the trailer in a new position, gouges in the ground indicated that in haste, they dropped the tongue before forward motion of the tractor and trailer had stopped and b*ggered up the jack by bending it!
They put me on a new one!
Brian.
Brian & Connie Mitchell
2005 Classic 30'
Hensley Arrow / Centramatics
12-30-2014, 07:22 PM
Biloxi
, Mississippi
I recently replaced my jack after it self destructed. The base cracked causing the gears to freeze up and shatter. Three bolts and one wire, took maybe 15 minutes from start to finish. I wish all the trailer projects was so easy.
MICHAEL
12-30-2014, 07:39 PM
asheville
, North Carolina
Thanks for the help, everyone. I will take one last look in the daylight tomorrow to see if the shaft is bent or out of line. Then its on to a new jack.
Have a great New Year!
12-30-2014, 07:49 PM
begorragirl
2017 25' Flying Cloud
Denville
, New Jersey
Mine made terrible noise and died. I was unhitching at Campground with grandchildren. The campground found me a trailer guy nearby, I drove the whole thing over and 10 minutes later all set with new one, less than $200.00. When I think of the yeRs I spent cranking.
2006 Bambi CCD ("EireStream!!")
2010 Funfinder
2005 T@B
2001 Teardrop, Mountain Hardware Tent
For some perfection takes a little longer...
12-31-2014, 10:53 AM
2003 30' Classic
Stratford
, Prince Edward Island
My jack would only go down but not up so I investigated and found the limiting switch has over heated and burnt out. I order two ( have to have a spare) and re-attached the wiring. It worked ok but I noticed sparking at one of the three bolts that hold the unit on the tongue. I took this bolt out and cleaned up the area and re-installed the bolt. No more issues and the jack works 100%.
Mac from PEI
Canada
WBCCI #4782
"Southern Belle"
'03 Classic 30'
'10 Toyota CrewMax
12-31-2014, 02:16 PM
Winemaker
2022 25' Flying Cloud
Avila Beach
I have another jack question, the jack on my 2012 28ft FC will go down but only go up if I switch it quickly while the gears are still turning up. If I let the gears "settle" it will not go up. Normally I would say a problem like this would be caused by the motor armature but...why only one direction?
12-31-2014, 02:52 PM
2004 30' Classic
Hillsborough
, New Jersey
power jack issue
I had a similar problem several years ago on my 2004 Classic. I called the company that made the jack and they gave me advice, send a part for free which fixed the problem. Good company.
12-31-2014, 03:16 PM
Winemaker
Avila Beach
Thanks, will give them a call and see what they say. I was hoping that I would get more then three years out of the unit!
01-05-2015, 09:41 AM
Storm Master
2005 25' Classic
Austin
Looks like the same Super Jack I had on our 05 Classic. Good jack but temperamental with me. Didn't care much for the sacrificial fiber gear that cost around $50 to replace. Bought a Husky 4500 with remote on sale at CW. Easy install and can level from inside the trailer with the torpedo level on the counter top. Makes hitching safer too. Can stand off to the side and raise/lower without getting in the crush zone when the other is backing. Hope it last a long time. Time will tell.
01-05-2015, 09:45 AM
2009 23' FB Flying Cloud
Canmore
, Alberta
Insure your batteries are still in good shape. I had endless similar problems with my power jack with my previous set of batteries, they were original and near the end of their useful life. New batteries solved the jack problem instantly.
