Old 03-24-2012, 08:28 PM   #15
kds
2008 27' Safari FB SE
Frederickburg , Texas
Originally Posted by Splitrock View Post
I used this one from this source.
"This A-Frame Jack has a Front-Facing Sidewind Crank with a High Quality Gear Train."
Bulldog A-Frame Trailer Jack HB-155010
Great company to order from. AAA+++
Received the A-Frame Jack you recommended yesterday and installed it today. Works great!!!! Thanks for the great info! I won't be stranded by my electric jack anymore and I was amazed at how easy it is to raise my AS.
Thanks again,
Kelly
kds is offline   Reply With Quote
Old 03-24-2012, 08:44 PM   #16
1975 27' Overlander
High River , Alberta
Thanks again,
Kelly
I installed an Atwood A-frame jack after my electric jack failed. Maybe not as strong as the Bulldog unit, but I'm very happy with it. I do not miss the electric jack. It does not take much strength to crank the handle.
AlbertF is offline   Reply With Quote
Old 03-24-2012, 08:54 PM   #17
Splitrock's Avatar
Sioux Falls , South Dakota
Thanks again,
Kelly
Glad it worked. Happy spring!
Old 04-01-2012, 04:15 PM   #18
Evergreen , Colorado
Having troubles with our power jack as well. Lift Rite 3000 model. For the past year it would work intermittently - I could often get it going though by getting in moving in one direction, then quickly going in the other direction with the switch. The unit wouldnt come on at all sometimes when I threw the switch. Finally it just stopped coming on completely.
I pulled it apart, tested everything with a voltmeter - but without a wiring diagram I'm not 100% sure Im testing it correctly. Long story short - I think it's a bad switch. Anyone know of a way to figure out if it's the switch? I seem to be getting power to the switch, and power to the limit switches when thrown.
Nightwatch is offline   Reply With Quote
Jack's '67 Safari 22' Jack McAllis 1966 - 1968 Safari 205 06-29-2015 07:58 AM
Electric Jack Not Working eberrobw Jacks, Stabilizers, Lifting and Leveling 13 03-13-2012 11:23 PM
Super Jack on 2005 CCD Int'l GT1963 Jacks, Stabilizers, Lifting and Leveling 3 03-04-2012 12:04 PM
Solar Power Quest Mr & Mrs S Boondocking 58 03-02-2012 02:03 PM
Jack problem chrischarles Towing, Tow Vehicles & Hitches 6 02-25-2012 07:45 AM
