Old 12-28-2018, 02:04 PM   #1
Cispook's Avatar
2017 27' Flying Cloud
Chillicothe , Ohio
Power jack
Light works. No power movement. Leave light on and push power switch and blows fuse. Checked all wires. Battery back is good. Sprayed electric cleaner. No change. Any help appreciated.
Cispook is offline   Reply With Quote
Old 12-28-2018, 02:17 PM   #2
2019 27' Globetrotter
Salem , Oregon
Sounds like it is jammed up. Try to use the crank that came with it to move it a little either way and see if that frees it up. Also plug and unplug all connections.
Good Luck.
Dave
NoResults is offline   Reply With Quote
Old 12-28-2018, 04:07 PM   #3
Cispook's Avatar
Chillicothe , Ohio
I tried that. No luck.
Old 12-28-2018, 05:51 PM   #4
KK4YZ's Avatar
2017 23' Flying Cloud
Hiawassee , Georgia
If this is the Atwood (or whatever theyíre called these days) it has a clutch that you should hear if the gears are refusing to move. I assume from the answer above that you tried moving it with the manual crank and it wouldnít budge?
Did you hear the clutch make a ratcheting sound like an electric screwdriver?
If not, I think you possibly have a shorted connection to the motor or the motor itself is shorted.
Iím not a fan of these jacks that AS supplies. Mine failed on the 3rd trip out. Atwood sent me a new one. If the 2nd Atwood fails there are better options out there. Husky I think is one.
KK4YZ is offline   Reply With Quote
Old 12-28-2018, 05:55 PM   #5
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Check here for a short...had to wrap and loom ours...👍
W. H. Auden
"The hardest thing about Airstreaming, clearing your head and accepting how others feel itís supposed to be done"Ö..
Amanamus
"Tahawus"
Old 12-28-2018, 08:11 PM   #6
Cispook's Avatar
Chillicothe , Ohio
It moves
Old 12-28-2018, 08:12 PM   #7
Cispook's Avatar
Chillicothe , Ohio
Iíll check that ... Iím leaning towards bad switch
Old 12-29-2018, 04:29 AM   #8
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Since the light works, that's a good bet.
2019 Ford Expedition Platinum
Old 12-29-2018, 06:22 AM   #9
KK4YZ's Avatar
Hiawassee , Georgia
Thereís a short in the circuit somewhere, switch, wiring, motor?
Old 12-29-2018, 07:52 AM   #10
Wayne&Sam's Avatar
Images: 21
I guess what I meant to say was that the power going in is OK since the light works. The switches are notorious for failing.
Old 12-29-2018, 08:44 AM   #11
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
I think my switches failed. Toward the end of last season, I had intermittent failures and successes raising and lowering the jack. The light hasnít worked for years. I bought new switches for both. Is it just a simple deinstall the old/reinstall the new - or is there any specific procedure I need to follow? Also assuming itís just solder to connect, yes?
Old 12-29-2018, 09:23 AM   #12
2007 22' International CCD
Usually itís push on connectors, blade type on the switch, female on the wiring. Get good pictures before you take it apart, make a sketch, and label the wires carefully before you proceed. Then be sure you have disconnected power from the Jack by pulling the fuse or disconnecting the battery negative wire first.
Old 12-29-2018, 09:58 AM   #13
W , New England
Thanks. Yes, the switches I bought (different part numbers based on the ownerís manual) are blades and the batteries are out now for the winter so I was planning on replacing them before my first trip in the spring (before installing the batts). So the blades donít pop in to a socket then I assume if I need to track the wires carefully.
Thanks for the help!
Old 12-29-2018, 02:34 PM   #14
Cispook's Avatar
Chillicothe , Ohio
Anyone know where I can download the manual for the Atwood 3000
Old 12-29-2018, 03:29 PM   #15
W , New England
Is this it? https://assets.rigidhitch.com/hitch_...powerjacks.pdf
I googled Atwood 3000 power jack user manual and got that link
Old 12-29-2018, 03:33 PM   #16
Wayne&Sam's Avatar
Images: 21
Same here this season. I had to crank it a couple of times, then later it worked. I plan on ordering the switch and replacing it before next season. I'm just too busy skiing right now.....
Old 12-29-2018, 03:36 PM   #17
Wayne&Sam's Avatar
Images: 21
BTW, My jack is a Barker.
Old 12-29-2018, 05:28 PM   #18
Cispook's Avatar
Chillicothe , Ohio
Thanks. Much appreciated.
Old 12-29-2018, 05:38 PM   #19
Power jack
Yes, the wires have individual connectors, so a good picture and diagram is essential to success.
The switch contacts are small, and quickly switching direction on the jack tends to arc the contacts and make them go bad. Itís best to wait a second or two for the motor to stop if changing directions. Makes the switch last a bit longer.
I plan to rip out the switch and substitute a set of sturdy relays controlled by a switch. The relays have much better contacts and higher current rating. Best part is they plug into a socket. If I get real silly Iíll add a wireless remote control to the mix. Yep, still the Overkill Engineering department around here.
Old 12-29-2018, 07:31 PM   #20
Cispook's Avatar
Chillicothe , Ohio
Power Jack needs shore power? cp1977 Jacks, Stabilizers, Lifting and Leveling 10 06-28-2018 06:36 PM
Power jack getting power. OffTheCouch Electrical - Systems, Generators, Batteries & Solar 11 01-01-2016 11:39 AM
To Jack or not to jack? Zstream Jacks, Stabilizers, Lifting and Leveling 7 12-17-2009 11:09 AM
Manual Jack Broken - Best Elec. Jack? montanaandy Jacks, Stabilizers, Lifting and Leveling 9 07-10-2003 06:33 AM
Jack Plates Jack Plates Inland RV Center, In Our Community 4 03-19-2003 03:34 PM
