I ran the jack up and down a few turns using the manual socket and attaching a set of vice grips. I thought about using my cordless drill ... concerned that it may torque and break something internal or the supplied socket.
We’re on the road so no repairs for at least a week.
Anyone replace the switch in past? Do you have to remove the motor?
Dump the Atwood and replace with the Super Power Jack by Barker (H&H Engineering). Airstream used these for years and then substituted them with the cheaper Atwood version. Mine is at least 25-30 years old and still clicking. I took it back to their manufacturing site once to get it tuned & lubed up because it would not work and the issue was that the powerhead had to be re-timed because of the limit switches.
Regards,
StevieB
WBCCI #1095
Looking at replacing once we return from the Winter sojourn
Light works. No power movement. Leave light on and push power switch and blows fuse. Checked all wires. Battery back is good. Sprayed electric cleaner. No change. Any help appreciated.
Hi Cispook,*
Please send us a direct message with your contact information and the last 6 digits of your VIN so we can share it with our Customer Service and Technical Support team.
Thank you.*
Official account for Airstream, Inc.
Airstream Customer Service and Technical Support can be reached at 1 (877) 596-6111, option 1.
