Old 11-15-2018, 07:55 AM   #1
2003 22' International
Gilroy , California
Power Jack
First off..thanks everybody for your great advice & opinions.
Now..yep, I need to replace this power jack also. The switches donít work right for one. Itís a Barker levelRite 3000. Are there other brands out there that you guys like ?
Tomorrowís question will be on replacement galley sink faucet !! That needs to go too.
Mr Gilroy is offline   Reply With Quote
Old 11-15-2018, 09:02 AM   #2
Half a Rivet Short
Carlisle , Pennsylvania
Hi
Not to keep you from buying a new toy ... but ... switches generally are a dirt cheap item to replace. Most of them are a generic size and type.
The biggest debate on jack replacement seems to be "how big?". At the very least, you are lifting the tongue weight of your trailer. With some WD hitches, some people also lift quite a bit more than that.
Just for reference, AS seems to have gone to 4,500 lb jacks across the board this year.
Leaping ahead to tomorrows question - the galley faucets seem to be pretty standard residential units. Lowes and Home Depot will happily sell you a wide range of ones that *should* fit. Going over and actually seeing the options probably is a good idea. Oddly enough, the faucet in our trailer is identical to the one in our kitchen here at home ....
uncle_bob is online now   Reply With Quote
Old 11-15-2018, 09:10 AM   #3
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Husky Super Brute $200-$400 depending on your source.
Uses a better screw lift bearing system and is therefore quieter, but because it is a 5000 lb jack, it is slower. Expect about 60 sec to run it back to travel position from down far enough to install the weight distribution.
Best - it is silver.
Barker has parts. They also have a similar jack design on their premium models. Barker is also American made and a similar price.
Travel safe and with a smile. Pat
PKI is online now   Reply With Quote
Power Jack needs shore power? cp1977 Jacks, Stabilizers, Lifting and Leveling 10 06-28-2018 06:36 PM
Power jack getting power. OffTheCouch Electrical - Systems, Generators, Batteries & Solar 11 01-01-2016 11:39 AM
To Jack or not to jack? Zstream Jacks, Stabilizers, Lifting and Leveling 7 12-17-2009 11:09 AM
Manual Jack Broken - Best Elec. Jack? montanaandy Jacks, Stabilizers, Lifting and Leveling 9 07-10-2003 06:33 AM
Jack Plates Jack Plates Inland RV Center, In Our Community 4 03-19-2003 03:34 PM
