Old 07-16-2011, 03:26 PM   #1
1970 31' Sovereign
farmington hills , Michigan
Images: 12
Power at the ball
i have a 70 as and the electric jack at the front was missing the motor and wires.the breakaway switch is also missing wires.question is,what wires go where.i have two wires to the front,a red with 12vdc and a yellow that has about 24 ohms to ground.im sure the red is my feed to the new jack but how does the breakaway switch work?
manymemories is offline   Reply With Quote
Old 07-16-2011, 04:11 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
The wire with 12 volts is power to the jack as well as power to the breakaway switch. The wire with continuity is most likely the trailer brake lead. To check this, simply apply 12 volts to the wire with continuity (make sure it has some kind of circuit protection in case we guessed wrong), and see if the brakes apply. The jack is self-grounding, and the breakaway switch doesn't use ground. The breakaway switch will operate with either wire connected to 12 volts.
Old 07-17-2011, 10:03 AM   #3
1970 31' Sovereign
Images: 12
thats exactly what it was,thanks for the feedback.
Power Loss & Pets Inside? Frank&Mike The Pet Forum 67 07-27-2013 08:57 AM
No Power To A/C (power at breaker) vhariable Electrical - Systems, Generators, Batteries & Solar 3 06-28-2011 05:54 PM
Stumped by power steering dadstoy Mechanics Corner - Engines, Transmission & More... 14 05-30-2011 01:57 AM
Hitch Ball for a Reese flyingcloud Hitches, Couplers & Balls 16 05-29-2011 09:28 AM
Power Steering Not Working - 310 Motorhome steveturk Classic Motorhomes 27 02-18-2011 05:00 PM
