Old 05-04-2004, 06:25 AM   #1
flamingo-kid1's Avatar
1967 28' Ambassador
Rockford , Illinois
Send a message via ICQ to flamingo-kid1 Send a message via AIM to flamingo-kid1
please look at my photos of jacking up problem
I would appreciate any comments anyone could give.. I entered a post earlier re: these slits in the wheel well after installing new tires and wheels, but here's the actual before and after pictures.
Does anyone have any ideas on how to repair?
Anyone seen this before?
Will it get worse? It doesn't seem to be in any support type of area.
Thank you in advance.
ID:	6389   Click image for larger version
flamingo-kid1 is offline   Reply With Quote
Old 05-04-2004, 06:41 AM   #2
Outriggers/stringers...
millionairstream is offline   Reply With Quote
Old 05-04-2004, 07:00 AM   #3
TomW's Avatar
1967 26' Overlander
Huntsville , Alabama
A closeup of your damaged area would help a lot. It looks like a puncture wound (from the outside) in your photo.
Are both sides damaged?
Tom
Old 05-04-2004, 07:25 AM   #4
1967 28' Ambassador
Rockford , Illinois
They are puncture wounds from the inside OUT, over three tires.. of course, on BOTH sides of the trailer.
One side has two punctures and the other side has a smaller slit just on one tire well.
We are shocked.
The tire installer was very careful and used two hydraulic jacks under an axle as he did one side of the trailer at a time.
Old 05-04-2004, 07:35 AM   #5
TomW's Avatar
1967 26' Overlander
I have to agree with millionairstream. Unfortunately, for this to happen, your floor would have to be soft around the edges in the wheel well area. As a corollary, the elevator bolts, which hold the floor to the outriggers, would either be loose or rusted away.
To confirm, either pull the carpet up, or take an ice pick and probe the interior floor around the damaged area.
The only invisible fix for the skin is to replace the damaged panel.
Old 05-04-2004, 07:48 AM   #6
Still Working
smily's Avatar
1994 36' Classic 36
North Charleston , South Carolina
Oops! bad jackman, bad jackman...............
Andy prevails again, he will be quick to tell you, NEVER JACK AXLES!
This is a huge topic of controversy here on the forum.
There are grave consequences when jacks are applied incorrectly to the axles, here is living proof.
I believe you will read that axle mounting plates are th only acceptable location for upward force to be applied to trailer.
The best course of action is to change one tire at a time. You drive one wheel of trailer up on ramp, (solid wood or comparable), to elevate the side of the trailer. This will leave one wheel suspended for change out., Repeat process for next wheel.
Smily
smily is offline   Reply With Quote
Old 05-04-2004, 08:01 AM   #7
59toaster's Avatar
1959 22' Caravanner
Atlanta , Georgia
Images: 22
I'd say it's either what ken said or worse. Where they jacked it didn't alow the axle to droop. They yanked the wheel till the skin gave enough to get clear of the hub. They proably jacked it off the shock mount on the swing arm so they pushed the wheel up into the fenderwell making the clearnece to pull it off even worse.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
59toaster is offline   Reply With Quote
Old 08-15-2010, 11:21 PM   #8
howco's Avatar
1970 27' Overlander
Sumner , Washington
TomW and millionaire stream, I (humbly) think your both mistaken, how is it this just happens 'immediately' after his tires are changed. I wouldn't happen after one day would it?
Flamingo even said the tire man put the jacks under the axles.
Am I wrong in assuming that there deliberate established 'jack points'
and they are to be used instead of the axels?
I admit, I am new at the A/S world, and do not have a clear understanding as to exactly the axels work as opposed to a auto straight axle, but what would that have to do with the outriggers/stringers???
Favorite Bumper sticker:
Yes, this is my truck...
No, I won't help you move....
howco is offline   Reply With Quote
Old 08-15-2010, 11:39 PM   #9
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
This why I change my own tires. I take 'em off, take 'em to the tire place, they mount new tires and I put 'em back on. BEFORE I installed new axles, which you may need, it was very difficult to remove the wheels down from inside the wells. New axles, my friend, and don't jack from the axles.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 08-16-2010, 12:31 AM   #10
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Educate me,
The tire is mounted to the drum which rides on the spindle which is welded to the swing arm which is welded to a bar that sits inside the axle tube that is bolted to the frame.
The whole trailer is sitting on the axle tubes so I am confused how it can be harmful to jack up the trailer with the jack on the axles.
What am I missing?
Bruce,
Parts needed: Fan for roof vent or whole vent fan assembly, vented catalytic heater.
My blog for the 1975 Tradewind restoration, Has not been updated in a while but I am still working on it.
bmklawt is offline   Reply With Quote
Old 08-16-2010, 01:11 AM   #11
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Originally Posted by bmklawt View Post
Educate me,
What am I missing?
Hi, jacking up your trailer by the axle tubes can bend the axles and change your alignment. Use Airstream's jacking points or the axle mounting plates only.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 08-16-2010, 01:14 AM   #12
Salem , Oregon
Images: 18
Hi, I think things will get worse if you don't replace those sagging axles. And this might be in part the cause of your problem.
2005 Safari 25-B
Old 08-16-2010, 04:37 AM   #13
Baltimore , Maryland
Bingo what Bob said on this now 6 year old thread. Those axles are totally sagged out.
Old 08-16-2010, 05:48 AM   #14
Outriggers piercing the underbelly wrap, is somewhat common.
The cause?
Vibration and flexing the shell excessively.
Unbalanced running gear, along with bottoming out because of bad axles, will do it everytime.
The fix?
Balance the running gear, address the issue of the axles, and replace the underbelly wraps.
Engine Revving Problem winner Mechanics Corner - Engines, Transmission & More... 19 02-08-2010 10:05 PM
Member's photos suggestion Rog0525 Our Community 13 01-12-2004 10:01 PM
Problem seeing photos mcneon Forum Admin, News and Member Account Info 1 11-12-2003 01:55 PM
Members Photos Richard Vroom Forum Admin, News and Member Account Info 4 09-21-2003 06:26 PM
Electrical problem resolved davidz71 Electrical - Systems, Generators, Batteries & Solar 5 08-12-2002 08:21 PM
