Old 03-04-2019, 04:40 PM   #29
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Originally Posted by Al and Missy View Post
There is a description of the battery wiring in the manual. It says that there are four separate battery cables, two positive and two negative. These four cables and a fifth from the TV are connected to five 30A circuit breakers mounted on a bus bar in your power distribution panel. You may have one or more failed circuit breakers, or loose connections on them.
Al
I went back to the pic I posted in #10 - I can see both positives and negatives - in fact, the thinner cables both have a blue crimp on them, the thicker ones are the standard post connectors, and there are jumpers to connect both batteries. The other cable (black with yellow crimp) is the positive from the jack. I know when I connected the single battery, I had ONLY the positive from the jack on the positive post of the battery - and the thin negative on the other post. So that would explain why the battery disconnect didnít work - the main positive cable or even the smaller positive cable wasnít connected to the battery so the circuit couldnít have been complete. And Iím wondering if the main negative cable needed to be on the battery as it must carry the ground from the jackís negative terminal being grounded to the frame.
If Iím right on that interpretation, it solves the entire mystery.
Of course - Iím rarely right
SteveSueMac is online now   Reply With Quote
Old 03-04-2019, 04:44 PM   #30
Long Island , New York
Hard to follow all the discussions of connections, but in my opinion one battery, connected properly, would work as well as two, given the low wattage draw of the jack motor.
Peter
Old 03-04-2019, 05:09 PM   #31
W , New England
Peter
Yup. The bottom line is I understand I didnít have the single battery connected correctly. It wouldnít have completed a circuit for the battery disconnect switch, or the ground from the frame.
When I go back to start the season - as a test - Iím going to hook up a single battery first to test the jack and battery disconnect that way. Iím 99.9% confident Iíll be able to report back a working jack on a single battery. I just didnít understand that side of things....
Old 03-04-2019, 05:12 PM   #32
2007 22' International CCD
To add somewhat to the confusion, if my batteries are dead, hooking up the 7-way connector from my Tacoma will boost the batteries enough to allow the jack to operate.
I suspect the charge lead in the umbilical is wired direct to the batteries before the house power use/store switch, like my solar panel controller output (once I fixed it..).
I suspect a certain amount of 'creativity' in the factory wiring the Airstream power circuits, to put it politely.
rmkrum is online now   Reply With Quote
Old 03-04-2019, 05:27 PM   #33
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
I like "creativity". It sounds so much nicer than the truth.
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Old 03-04-2019, 05:37 PM   #34
W , New England
Let me see if I get this...
Remember - I did not have the single trailer battery connected properly. So IF the 7-pin sends some power to the batteries (which apparently it does for charging) the batteries (or battery) would have to be connected properly to complete that circuit. Since they werenít/ it wasnít, the tow vehicle would have been incapable of sending power to/through the battery to the jack? Yes?
The clearance lights must get their power directly from the tow vehicleís battery....- or - when you jump the 12v and clearance light blades (assuming your trailer batteries are connected).
And not that thereís any risk of this - but people shouldnít interpret anything Iím saying here as good advice! More like feeling my way around a mystery without any real knowledge of how things work...
Very much appreciate everyoneís help and patience!
Old 03-04-2019, 05:49 PM   #35
Al
Unfortunately, in my role as a certified old Phart, the head of the Overkill Engineering Department, and opinionated old cuss that worked for Boeing, I've learned to disconcert folks by occasionally being excessively diplomatic in my forum discourse occasionally, just to avoid irritating the moderators, who I am sure have more than enough stuff to ride herd on...
How's that for a run-on sentence, and polite obfuscation of the 'truth'?
Old 03-04-2019, 11:00 PM   #36
Zymurbrian's Avatar
2012 25' FB Flying Cloud
Roseville , California
I Recently changed out the jack on my 2012 25FB because of exact same issues that you describe. Unfortunately, half way through the process I learned that I had wasted the money on the new jack. The entire issue was the ground. Corrosion had built up around the washer connecting the jack to the A frame. Simply cleaning the connection well, changing out the star washer and applying dielectric grease solved the problem. I suspect that you actually solved the issue by cleaning the ground on your jack.
Zymurbrian is offline   Reply With Quote
Old 03-05-2019, 10:57 AM   #37
W , New England
Well that would be more ironic than changing the light switch for a bad bulb! These two switches werenít cheap....oh well. Iím learning a ton!
The tip on dialectic grease is a good one - I will add that when Iím back at the trailer. Thanks!
Old 03-05-2019, 05:22 PM   #38
2017 19' International
Tallahassee , Florida
Same here.
My Airstream came from the dealer with batteries mortally wounded. First camping trip, batteries were barely spitting sparks and the jack wouldn't budge.
Out of desperation, I plugged in the 7-way and cranked up the Suburban. Jack worked. In a tired fashion, but worked well enough that I could hitch up the trailer.
WhereStream is offline   Reply With Quote
Old 03-05-2019, 05:37 PM   #39
Yup. Our second set of Golf Cart batteries were boiled to death by the cheap convertor in the AS over a winter. Was convenient to leave it plugged in to keep it warm. Was able to get it out of where it was stored only because the charge line was hooked to the batteries all the time. Not enough juice to operate the use/store switch even.
Managed to refill the water in the batteries and jump them to get enough power to run the breakaway switch, and have some power for a few months, but that set was eventually totally shot. New convertor is in it, and I added a battery watering setup to make it a lot easier to top off the water. Now I just check/add water once a month, and don't even have to pull the caps off to do it.
Old 03-05-2019, 05:54 PM   #40
AlinCal's Avatar
1991 25' Excella
2011 19' Flying Cloud
Santa Ynez , California
Take away summary.
Batteries need to be installed and wired (correctly) for 12 volt system to work, either on there own or thu the 7 pin.
Probably best to diagnose electrical problems with a multimeter rather than trial and error unit replacement.
Good judgment comes from experience, and a lot of that comes from bad judgment.
Will Rogers
Alan
AlinCal is offline   Reply With Quote
Old 03-06-2019, 03:16 AM   #41
Another take-away [good meter suggestion, Alan] is that some of the first posts in this thread mentioned checking the ground.
The weakest link in a chain . . . it only takes one . . .
Old 03-06-2019, 04:14 AM   #42
W , New England
Please help diagnose my jack problem
...snip...
Yes indeed - the *very* first post mentioned that - I know the guy who wrote it...
But yeah - testing (instead of guessing) is absolutely a more efficient way of getting to an electrical solution. Of course, in that case, we wouldnít have had so much fun in this thread and I may or may not have wasted money on switches
As Mike Brady would say ďwell kids, I think weíve all learned an important lesson today.Ē
Hot Hub /Wheel - Help diagnose Please Sav'h Steve Brakes & Brake Controllers 27 04-21-2011 08:39 PM
how do I diagnose frame damage on '59 18-footer CindyH Repairing/Replacing Floor &/or Frame 0 03-11-2011 01:43 PM
Battery Drain? - Diagnose TankerIP Batteries, Univolts, Converters & Inverters 12 09-20-2007 07:01 PM
Can you diagnose my univolt / power problem? mwmoss Electrical - Systems, Generators, Batteries & Solar 17 09-06-2006 10:18 PM
How do I diagnose the soft spot, and what are the repair options? Narnian Repairing/Replacing Floor &/or Frame 12 09-01-2003 02:41 PM
