Old 02-19-2011, 06:51 PM   #1
Spring Hill , Florida
Placement of jack for lifting
Ok, am I correct that that vertical plate with the D-shaped holes is the axle mounting plate? That what it looks like the jack stand is on in Splitrock's picture. I put my jack on that, in between the wheels, and the plate bent. What am I doing wrong?
dorfgog is offline   Reply With Quote
Old 02-19-2011, 07:14 PM   #2
Splitrock's Avatar
Sioux Falls , South Dakota
Right place, wrong jack me thinks. Get a bottle jack. Your jack has to be on concrete and free to roll as it goes up and down.
Old 02-20-2011, 08:35 AM   #3
Smile
Thank you, now it makes sense. It warped because the jack couldn't roll as the trailer tipped. How big a bottle jack does it need to be? I assume they come in more than one size. And any ideas on how to bend back the warped plate?
Old 02-20-2011, 08:44 AM   #4
Maniacal Engineer
barts's Avatar
Menlo Park , California
Even the smallest hydraulic bottle jack will lift your trailer.... my 12 ton jack laughs lifting less than 2500 lbs, which is what our tradewind weighs per side.
How much of the plate is bent?
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 02-20-2011, 09:00 AM   #5
Attachment 122586
Look at the back side of the axle mounting plate, where it's welded to the bottom of the frame.
The welds do not need to make a complete "seam", but back then, all to many times the distance between the welds were 8 to 10 inches. That then allows the axle mounting plate to bend in those areas, since there is no additional strength added to that area.
Usually, when the absence of weld is the problem, "C" clamping the frame to the axle mounting plate, in those areas, will bend the plate back into position so that it can be welded to prevent the same problem at a later date.
If you don't weld it, it will get worse, in time.
Old 02-20-2011, 10:41 AM   #6
2009 27' FB International
Does anyone have a picture of the correct jack placement on a late model tandem axel?
Alan3940 is offline   Reply With Quote
Old 02-20-2011, 11:02 AM   #7
tpi
Trabuco Canyon , California
This is not my picture, got it thru google image search. The jacking is the same on late model trailers. It is very easy to lift trailer using bottle jack on axle mounting plate.
tpi is offline   Reply With Quote
Old 02-20-2011, 01:10 PM   #8
Halimer
2006 25' Classic
New Hyde Park , New York
The above photo is how they do it at Jackson Center.
halimer is offline   Reply With Quote
Old 02-20-2011, 04:13 PM   #9
_
really?
wasn't how they jacked the 34 ftr,
or any other trailer in the service bay during my visits.
well, during my 2dozen visits.
with picture proof directly from the j/c shop floor in post # 42 below...
this lengthy thread may help U (or just muddy the issue)
http://www.airforums.com/forums/f457...tml#post428907
there is also a picture/drawing in the a/s owners manual.
while is is rumored here that the factory folks and manual writers are wrong and don't know HOW 2 jack...
i tend to believe that they DO know jack on this issue.
________
the green 'bottle' pic above is right here too, in that thread.
while mr greeeeen is technically a mechanical screw jack,
which have been used 4 over a 100 years in construction, railroads, house leveling and so on...
SELDOM (never really) are they used to 'jack' autos, trucks, OR rvs.
the bar used to rotate the head is long and heavy and usually will not clear the wheels or other dangly bits.
so typically a hydraulic jack is used to LIFT,
and the bottle/screw is used 4 a safety stand, or long term support after lifting.
and in that application it becomes a jack STAND, like the more common ratcheting variety.
cheers
2air'
Old 02-21-2011, 03:14 PM   #10
Here are some pics of the damage to the axle mounting plate. The other side is similar. The main thing, it seems to me, is that the shock absorber mounting bolt is tilted upwards. Is there anything I can to to try to bend it back straight, or just leave it alone?
ID:	122791Click image for larger version
ID:	122792Click image for larger version
Old 02-21-2011, 03:56 PM   #11
That bend in the axle mounting plate won't hurt the shocks at all.
Old 02-21-2011, 08:45 PM   #12
So, Andy, as long as there is no separation between the mounting plate and the frame, should I just leave it alone?
Old 02-22-2011, 10:05 AM   #13
Of course.
Don't look for a problem, when there is none.
So the axle mounting plate is bent, so.......... It not hurting anything.
Old 02-22-2011, 02:36 PM   #14
Yaaaaaa, good news for once! Thanks to everyone for the help
Jack Digital Over-the-Air Antenna Tallytown Audio, Video & TV 21 02-17-2013 11:19 AM
OK to use a jack instead of blocks to level? KYAirstream Jacks, Stabilizers, Lifting and Leveling 27 09-18-2012 06:42 AM
Placement of lower curtain tracks over back gaucho 73 Tradewind. constructor Upholstery, Blinds, Walls & Interior Finishes 1 03-17-2011 06:22 AM
Cable jack options for exterior skin NicheVintage Audio, Video & TV 8 01-30-2011 06:20 PM
Can't unhitch! Need help. LawChick Hitches, Couplers & Balls 43 01-11-2011 02:10 PM
