Old 10-03-2003, 11:19 PM   #1
eikel1we's Avatar
1975 25' Tradewind
, Michigan
Send a message via AIM to eikel1we
placement of jack
I've been looking and have now lost patience - I believe I've seen it some place before. Can someone please tell me where the thread is about proper placement of the jack while doing a bearing repack? (and can I assume for fixing a flat it would be the same location?)
Thanx,
suz
sue and ike
'75 Tradewind - 25'
"Cupcake" air-912
2004 GMC Yukon XL 2500
Michigan - "middle of the mitt"
eikel1we is offline   Reply With Quote
Old 10-04-2003, 12:42 AM   #2
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Hi Suz
There are quite a few threads on the subject but THIS may be the one you're looking for.
Did you guys move? I thought you were in Saginaw Twp.
Rog
Rog0525 is offline   Reply With Quote
Old 10-04-2003, 03:47 AM   #3
71tradewind's Avatar
Sue ,on both my "71" &my "74" Tradewinds there is a square patch about 3" sq that is just behind the rear wheels ,if I recall there is an arrow on it . That is jacking location. But I follow what the manual says to for changeing a flat , just place some blocks in front of or behind the wheel,depending which axle your doing and pull the trailer up on the blocks ,lifting the adjacent tire and axle high enough to get the tire and wheel off . This is an easy,Safe ,way of doing it .
71tradewind is offline   Reply With Quote
Old 10-04-2003, 12:47 PM   #4
eikel1we's Avatar
1975 25' Tradewind
, Michigan
Thanx for the replys. I printed out the info at Rog's suggested site (5 pages worth - is there a way to highlight and just print the post(s) you are interested in?)
Yes Rog, we did live in Sag Twp. Just moved north 5 wks ago today.
Glad you have your sought after 19'. Hope to see it and meet you sometime- maybe at the Mackinaw City Rally?
suz
sue and ike
'75 Tradewind - 25'
"Cupcake" air-912
Old 10-04-2003, 01:07 PM   #5
Rog0525's Avatar
Images: 11
Suz, what I do is just copy and paste the text I want to keep to Wordpad or Notepad and print from there.
When is the Mackinaw rally? One of my brothers lives about halfway between here and there and it might be a fun trip to plan.
Rog
Old 10-04-2003, 01:14 PM   #6
Make sure tire shop puts jack in right place
I had a tire failure on the road last Fall. I found a tire shop that had a new tire but the installer put his jack right under the belly pan that covers my black water tank. I was in the shop office and didn't see him put it there. When I went out to check on the installation the belly pan had crushed in.
I had the installer make a note of the damage on the bill and told him that if I had a leak I would expect them to pay for it. I have not noticed a leak but there could be some damage that I cannot see.
Wayne
wayner1239 is offline   Reply With Quote
Electric/Manual Jack Security Question docbluedevil Jacks, Stabilizers, Lifting and Leveling 1 11-02-2003 12:50 AM
Jack placement Chitown AirStreamers On The Road... 10 10-07-2003 09:56 AM
Moving the camper without the front jack wheel Silvertwinkie Our Community 9 07-22-2003 07:46 PM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 02:51 PM
Jack Resync jcanavera 2001 Safari 1 07-03-2002 11:45 AM
