Old 12-14-2016, 10:24 PM   #1
Michael Wild
1978 31' Sovereign
1984 31' Airstream310
Edmonton , Alberta
OEM Super Jack Parts (aka Tongue Jack)
Hello Airstreamers,
I am really hoping someone will be able to help me out.
I just spent the last three days restoring the Super Jack from my 1978 Airstream 31' Sovereign. I was just about to reassemble the unit when I dropped the electric motor housing and cracked one of the curved magnets inside. See attached photos. I am so upset with myself, all this work and now I can't use it.
Is there any chance someone out there has one of these old Super Jacks around and if yes can I buy the magnet/motor housing/motor off of it from you?
The part number/markings on the motor are:
REDMOND
8
PE2424Q 12VDC
As you will see from the photos, I really only need the one magnet, but it may be better/easier just to get the housing or motor.
If you don't have the part, do you know a place where I can buy one?
Enjoy your day,
Michael Wild
780.970.1020 mobile
Michael_Wild is offline   Reply With Quote
Old 12-15-2016, 03:55 AM   #2
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Photos did not post
Old 12-16-2016, 09:20 AM   #3
Michael Wild
1978 31' Sovereign
Edmonton , Alberta
OEM Super Jack Parts Photos
Tongue-Power Jack Restoration/Rebuild
I dropped the electrical motor housing and broke one of the two magnets inside :-(
The part number/markings on the electric motor housing ar:
REDMOND
8
PE2424Q 12VDC
Old 12-16-2016, 09:47 AM   #4
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
I have a Barker Superjack that I replaced with an Atwood. It was making some strange noises on the downstroke. Its yours but I bet the shipping to Canada might be prohibitive. I probably could remove the head and just ship that and chuck the shaft.
Kelvin
Old 12-16-2016, 11:52 AM   #5
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
I replaced the Super Jack on my trailer because the original one quit working altogether.
I still have it, though.
I will look to see if I have the parts you need.
I replaced it with a new Super Jack that made funny noises as Kelvin mentioned. I asked the guys at Barker about the noise. They said that the noise was because the jack was new and the noise would go away with use. At first I thought that was a bunch of baloney, but the noise has gone away. The explanation was that the brake (?) was really tight on new jacks. Apparently other brands aren't noisy when new.
The reason I replaced with another Super Jack was to retain the original appearance of the trailer, although the gray paint on the new one is a shade off...
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 12-16-2016, 12:41 PM   #6
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
JB weld?
try some jb weld on that broken magnet,I bet it will still work like a charm.
desertair27 is offline   Reply With Quote
Old 12-16-2016, 12:45 PM   #7
Michael Wild
1978 31' Sovereign
Edmonton , Alberta
Originally Posted by KJRitchie View Post
I have a Barker Superjack... Its yours but I bet the shipping to Canada might be prohibitive. I probably could remove the head and just ship that and chuck the shaft.
THANKS Kelvin! All I need is the motor assembly. I am happy to send you an email money transfer in advance to cover shipping costs. Please email me at Michael@theWildsLife.com or txt at 780.970.1020 so we can figure out the details.
I can also do a quick video showing how to disassemble the motor from the tongue jack's head.
Old 12-16-2016, 12:47 PM   #8
Michael Wild
1978 31' Sovereign
Edmonton , Alberta
When I first saw the broken pieces that was my first thought, but now that it is two pieces, the polarity is reversed so they push away from each other.
Old 12-16-2016, 12:50 PM   #9
Michael Wild
1978 31' Sovereign
Edmonton , Alberta
Originally Posted by m.hony View Post
I replaced the Super Jack on my trailer...
THANKS M! Kelvin above also replied, so hopefully one of you can send what I need.
Old 12-16-2016, 01:14 PM   #10
m.hony's Avatar
2013 30' Classic
I might just send you the entire head.
TAC #MS-10
Airforums #70955
Old 12-16-2016, 01:28 PM   #11
Michael Wild
1978 31' Sovereign
Edmonton , Alberta
That works too. I had trouble removing the two set screws that attached the head to the shaft, eventually I just drilled them out.
Old 12-16-2016, 02:22 PM   #12
m.hony's Avatar
2013 30' Classic
The set screws may already be out of mine.
When I decided it was shot and ordered a new one I didn't bother to put it all the way back together.
If the set screws are still there, they can be removed- not rusted.
We'll see at some point when it is daylight and not raining...
TAC #MS-10
Airforums #70955
Old 12-17-2016, 05:13 PM   #13
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Here is a photo of my Barker. Is this the same one you need parts for?
Kelvin
Old 12-17-2016, 07:07 PM   #14
m.hony's Avatar
2013 30' Classic
Kelvin's is identical to mine.
TAC #MS-10
Airforums #70955
Old 12-17-2016, 10:48 PM   #15
Michael Wild
1978 31' Sovereign
Edmonton , Alberta
Ok, so mine is the older version from the 70's, BUT I know the gears are interchangeable, I am not sure if the motor is. Any chance either of you (M. or Kelvin) could take a pic of the motor and provide rough measurements (diameter and length)?
Is there anyone else out there with one of the older SuperJacks?
Thanks in advance, I really appreciate the help the forum members have given so far.
Old 12-18-2016, 04:11 AM   #16
m.hony's Avatar
2013 30' Classic
I can't post pictures because I am not a supporting member.
TAC #MS-10
Airforums #70955
Old 12-19-2016, 01:55 AM   #17
Michael Wild
1978 31' Sovereign
Edmonton , Alberta
You can email me at Michael@theWildsLife.com
Old 12-19-2016, 01:21 PM   #18
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
Actually you can and have posted pictures. However there is a limit for that with out upgrading your membership. In your case you have reached the limit.
Choices are:
Delete some of your current pictures.
Upgrade your membership
Or do nothing.
>>>>>>>>>>>>>>>>>Action
Old 12-19-2016, 02:47 PM   #19
m.hony's Avatar
2013 30' Classic
I am aware of all of that.
TAC #MS-10
Airforums #70955
Super cab or super crew ? Papa smurf Tow Vehicles 30 12-24-2014 09:19 PM
OEM parts? the_bosco General Repair Forum 13 04-06-2012 07:30 AM
Rub Rail aka Body Trim aka ??? ukinusa Ribs, Skins & Rivets 3 02-16-2011 05:42 PM
OEM Airstream parts buffet breez General Repair Forum 11 04-15-2009 09:20 PM
Super jack parts ctdair Jacks, Stabilizers, Lifting and Leveling 1 04-27-2004 06:49 AM
