Old 06-12-2010, 05:39 PM   #1
1998 34' Limited
christiansburg , Virginia
No power to jacks are there fuses??
I just bought a 1998 34 limited with elec jacks and can't find a fuse panel. I've tested every wire going to them and don't have power.where would they have brought power from?? I've got a block behind the couch and a small breaker box above the bed.are there any other panels??
Dewayne
gretchen is offline   Reply With Quote
Old 06-12-2010, 06:47 PM   #2
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
[deleted] Whoops. 1998 34 Limited ....not a 345 MH!
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 06-12-2010, 06:51 PM   #3
Cantrell's Avatar
1988 34' Limited
1960 24' Tradewind
Mt. Pleasant , South Carolina
Dewayne,
Don't know if this will help as our trailers are 10 years apart.
The control panel for our electric stabilizers and tongue jacks is in a storage compartment located on the front of the trailer between the tongue and the windows. On that panel is a screw out glass fuse for the entire panel.
Hope this helps.
Bill Cantrell
AIR 24338
TAC SC-1
__________________________________________________
Easily distracted by shiny objects.
Cantrell is offline   Reply With Quote
Old 06-12-2010, 07:58 PM   #4
2008 28' Safari SE
winter garden , Florida
on the 08 there is in in line fuse under the trailer about where the gas tanks are
bob34787 is offline   Reply With Quote
Old 06-12-2010, 10:57 PM   #5
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Our aftermarket power jack has an inline fuse near the jack where the wireing disappears into the frame. Inline fuses will be near the jack. The power source is the charge line from the tow vehicle.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 06-13-2010, 01:31 PM   #6
Ready-to-Travel
pmclemore's Avatar
2012 30' International
Walkerton , Virginia
I think he is referring to the electric stabilizers - the (two) controls are located on the street side, front and rear.
There is a fuse for the front and one for the rear, near the switches - have you checked those? If it is not that, then I would suspect that a 12-v fuse at the inside front of the trailer is at fault. Should be in the panel behind the couch.
I have a 98 31' Limited and am assuming yours is similar to mine.
Pat
Somebody, please, point me to the road.
AIR 3987
TAC VA-2
WBCCI 4596
pmclemore is offline   Reply With Quote
Power Jack Fuses SilverGate Jacks, Stabilizers, Lifting and Leveling 41 04-01-2014 07:45 AM
Blowing fuses on shore power fotochop Lights - Interior & Exterior 16 01-27-2010 08:00 AM
Power Jacks - Any Cautions? pmclemore Jacks, Stabilizers, Lifting and Leveling 13 10-24-2005 09:04 AM
Need fuses... JMGAZ Electrical - Systems, Generators, Batteries & Solar 5 07-22-2005 05:24 PM
Power Jacks Krazykraut Mechanics Corner - Engines, Transmission & More... 2 06-01-2005 10:00 PM
