Old 09-11-2010, 10:09 AM   #1
1977 31' Sovereign
Ft. Meade , Florida
Newbie
We have a new toy and would like to replace tires, the "manual" says there are jack points behind axles. But we can't find the jack placement. please advise, 1977 31' sovereign.
cb
Cathymb6 is offline   Reply With Quote
Old 09-11-2010, 10:16 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Welcome to the forums!
The easiest and safest way to change tires on a dual axle trailer is to roll one tire onto a ramp and then remove the one in the air.
If you need to jack, the mounting plate for the axles would be my choice.
Richard
Old 09-11-2010, 10:18 AM   #3
arodriguez60's Avatar
2008 27' Classic FB
1959 22' Flying Cloud
fairview , New Mexico
Images: 85
You have tandem axles. The easiest way is to drive it on top of some kind of ramp. use 2x6's or car ramps or something simular. Drive on the ramps leaving two wheels on the ramps and two in the air and remove two at a time. loosen lug nuts before you drive on the ramps.
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 09-11-2010, 11:28 AM   #4
87MH's Avatar
1978 31' Sovereign
Images: 292
cb
Note that there are two sets of 2 X 12's here - the blue, white, and green angled "ramp" section can be removed after the trailer axles are positioned on the green rear section.
Driver's side has an identical set.
The white object just to the rear of the bottom 2 X 12 is a 2 X 4 that is perpindicular to the length of the trailer. This 2 X 4 is anchored to the concrete drive. I use this 2 x 4 as a stop to prevent the "ramps" from skidding back as I raise various vehicles on the ramps.
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign
Texas Airstream Harbor, Inc.
Old 09-11-2010, 11:37 AM   #5
x
XXXX , XXXX
As richard says use the axle mounting plates if you want to jack it up. DO NOT DO NOT jack under the axles itself it will damage the axle tubes and ruin the axle.
wasagachris is offline   Reply With Quote
Old 09-11-2010, 11:43 AM   #6
cb
Those jack points listed in the owners manual, are for stabilizing jacks, not lifting jacks.
Easiest place to lift the trailer, is by placing a javck between the tires and on the axle mounting plate.
However, the safest, when time is not an issue, is to use a couple of 2 x 6's for a ramp for just one of the tires, as others have posted.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 09-12-2010, 02:02 PM   #7
1977 31' Sovereign
Ft. Meade , Florida
Great info, thank you for your post. Got it done.
Help for a Newbie? Heaviside Member Introductions 7 09-07-2009 06:23 AM
53 FC Newbie Xstream Member Introductions 4 03-29-2009 09:30 AM
NJ Newbie 2dabeach Member Introductions 3 11-23-2006 10:44 PM
Newbie ShantyPeople Member Introductions 6 11-23-2006 09:58 PM
The newbie again rebel beck Our Community 4 10-18-2005 09:10 PM
