Old 09-22-2019, 05:58 PM   #1
2016 25' Flying Cloud
z , Texas
New tires Jack Points
Wanted to ask the experts, I am getting new tires but only see 2 jack points on both sides, behind the rear wheel. I have 3 questions
1. Is it ok to raise both tires off the ground on one side using this one jack point?
2. Should I detach the TT from the TV when at the tire store
3 should I expect them to balance the wheels?
5150mike is offline   Reply With Quote
Old 09-22-2019, 06:25 PM   #2
2007 22' International CCD
Balance the tires. Insist on it. They may say itís not necessary, if so, Iíd go somewhere else...
Leave the tow vehicle hitched, in park, parking brake set, in a level area. Stay out of it while they are working.
Jack points will lift the trailer no issue.
Keep an eye on them so they donít jack on your axle tubes. That will wreck the axle. If they try to do so, stop them and go elsewhere immediately.
rmkrum is online now   Reply With Quote
Old 09-22-2019, 06:54 PM   #3
z , Texas
Thank you
Old 09-22-2019, 08:57 PM   #4
SSquared's Avatar
2013 25' FB Flying Cloud
Longmont , Colorado
On your dual-axle Airstream, you can change a tire without jacking the trailer up at all. You just pull one wheel up on a stack of blocks or a "trailer aid" ramp. The other tire is lifted off the ground.
When I got tires on my 2013 25FB, the tire shop was happy to have me do this--it eliminated the risk of them jacking it wrong. For our trailer, it takes a four-high stack of plastic blocks. We have enough to do both sides at once, so the shop can swap out two tires at a time.
SSquared is offline   Reply With Quote
Old 09-23-2019, 10:08 AM   #5
pappy19's Avatar
2002 30' Classic S/O
Garden Valley , Idaho
For double axle Airstream trailers, the Trailer Aid is worth every nickel. Much better and safer than blocks. Makes changing tires a snap.
2008 F-250 4X4 Lariat V-10
2007 Kubota 900 RTV
1996 Ford Bronco
2007 Lincoln LT
pappy19 is offline   Reply With Quote
Old 09-23-2019, 11:18 AM   #6
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Yes, No ,Yes.
2019 Ford Expedition Platinum
Wayne&Sam is online now   Reply With Quote
Old 09-23-2019, 12:52 PM   #7
2019 25' Flying Cloud
Hendersonville , North Carolina
Tire Balancing
Have them use the stick on weights that go on the inside surface of the rim instead of the ugly hammer on lead weights that damage your rim when hammered on. Much neater appearance and no damaged edges.
uraljohn is offline   Reply With Quote
Jack points, 1989 Excella 32', pics cjack99 Jacks, Stabilizers, Lifting and Leveling 1 06-26-2011 05:00 PM
Jack Points on 21 ft. 1995 Sovereign? johnobuttons Jacks, Stabilizers, Lifting and Leveling 4 07-31-2010 03:26 PM
Jack Points "77" Argosy 24 BigMike Jacks, Stabilizers, Lifting and Leveling 3 08-02-2008 05:35 PM
Jack points and Duratorque axles ray matthews Axles 3 03-06-2005 05:26 PM
Where are the jack points? barbwire All Argosy Trailers 6 11-11-2002 09:52 AM
