Old 09-26-2011, 06:01 AM   #1
MStewart's Avatar
2011 22' Sport
New Market , Virginia
New owner, problem with electronic hitch (stab jack)
Have asked the dealer and awaiting a reply re the following hitch issue. Picked up a new 2011 22' Sport on Friday. Had an electronic hitch put on before picking it up. Saturday morning the hitch would not operate: it has two switches, one for a light and one for raising and lowering.
Checked the fuse on the wiring and indeed it was blown. Got a box of 5, 30 amp fuses and those all blew. Looked more closely at the original fuse and it said 30 amp, 125 V. After several stores, found a 30 am up to 225 Vac. Those blew too.
So, we're stuck with a trailer connected to our truck. Any advice?
Other than this, we thoroughly enjoyed the weekend. Thanks much.
MStewart is offline   Reply With Quote
Old 09-26-2011, 06:07 AM   #2
DMT
DMT's Avatar
2011 27 FB International
East Coast , Newfoundland
Sounds like there is a short in the wire. I would go back to the dealer an have it repaired under warranty.
In the meanwhile you can use the manual crank to raise the trailer. Did the dealer show you how to use it?
[AIR# 55762 TAC# NFL-1
DMT is offline   Reply With Quote
Old 09-26-2011, 06:24 AM   #3
MStewart's Avatar
2011 22' Sport
The only thing found was the stabilizer crank and no, wasn't shown how to use it. Dumb on my part not to ask.
Tried to Google the name on the top of the hitch "Heavy Duty Levelite" but no luck.
Ugh, the dealer is a five hour drive away.
Thank you for your suggestion re a short in the wire. Was beginning to suspect as much, but thought I might be missing something that would be easy to address.
Maybe they'd be willing to have me take it to somewhere closer. One can only hope. Thank you again.
Old 09-26-2011, 07:31 AM   #4
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
MS,
Check where the jack wire runs under the LPG tank cover, notorious for shorting there. I covered ours with a split spiral wire loom. It may also be that the limit switch is out of sync. Procedure should be in the manual supplied by the manufacturer,(should be in the AS manual.)
PFC
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 09-26-2011, 07:34 AM   #5
MrUKToad's Avatar
2011 28' International
Chatham , Ontario
The first time I used my electric jack at home, the fuse blew. I checked the wiring, which is mercifully short and easy to access and all was OK. That said, my wiring does route through a small notch at the bottom of the LPG cover, which will be a weak point in years to come I think. I replaced my fuse and it's been fine since, so I hope yours gets sorted easily.
That experience was a grand way to find out how to use the manual crank, something I am now quite an expert at :~)
Steve; also known as Mr UK Toad
"You can't tow that with that!"
http://toadsoftowedhaul.com
MrUKToad is offline   Reply With Quote
Old 09-26-2011, 07:47 AM   #6
Pahaska's Avatar
2014 Interstate Ext. Coach
Hays County , Texas
First of all, you can unhitch by using your tow vehicle jack under the tongue. May have to use come blocks to get enough height. I have done that with my 28 in an emergency.
Second, there should be info on the jack in your owner's manual that specifies how to manually raise and lower it.
Some jacks do not come with an emergency crank. You have to remove the top cover of the jack where you will find a hex nut on top of one of the gears. Use a socket wrench to raise or lower the jack. Don't remove a gear or you will run into limit problems on the jack.
John W. Irwin
WBCCI #9632
Old 09-26-2011, 07:51 AM   #7
Silver Otter's Avatar
2011 31' Classic
Nellysford , Virginia
So, more learning for this newbie . . . I've taken the SuperJack cover off, but can't see a place to PUT the manual crank. Does one take the whole motor off? If so, how is that done?
Linda Heuer. President Shen. Valley Unit
Greg Heuer, 2nd VP Shen. Valley Unit
2011 31' Classic Ltd. - The Silver Otter III
2013 GMC Denali 2500HD 6.6 DuraMax - Sierra Blanca
TAC VA-18 | WBAC 1927 - Shen. Valley Unit 149 | AIR 53869
with Corey, the Norwegian Forest Cat
Silver Otter is offline   Reply With Quote
Old 09-26-2011, 08:01 AM   #8
You must take the complete motor off of the "jack".
It's held in place with a couple of allen screws that are near the bottom of the round part that slips over the jack.
Old 09-26-2011, 08:20 AM   #9
SilverGate's Avatar
2007 23' Safari SE
San Diego , California
My Super Power Jack uses a 30 amp slow-blow fuse.
SilverGate is offline   Reply With Quote
Old 09-26-2011, 08:24 AM   #10
2008 27' International CCD FB
Visalia , California
If your jack is like mine, there is a level on the top of the jack, turn the level holder and remove it, under where the level was is the square end of a shaft that is used with the crank. You might want to remove the propane tank cover to give you more room to crank. I had the same brand jack on my 2008 27' International, I just replaced it this past week--it got to t he point of me not knowing if it would work or not, had to use the crank once too often.
Good luck
Chuck
ThreeFingers is offline   Reply With Quote
Old 09-26-2011, 08:27 AM   #11
From the H&H Super Jack instruction sheet....
Operation.. manual
remove powerhead by loosening the two allen head set screws holding it to the jackpost.
The emergency handle may be inserted into the jackpost and the jack can be raised of lowered.
Synchronize the powerhead..
Use the crank to fully retract post
crank jackpost one turn in the opposite direction
ground powerhead to jackpost or trailer frame
push switch away from jackpost (as if retracting) Hold switch until motor stops running (as if jackpost is retracted all the way)
install powerhead and tighten set screws.
PFC
RLC
Old 09-26-2011, 08:36 AM   #12
richinny's Avatar
2011 34' Classic
is the fuse blowing as soon as you plug it in or does it blow as soon as you activate the power switch?
Ricky
Old 09-26-2011, 08:38 AM   #13
I just went to my storage shed and my jack that I took off is a Heavy Duty LevelRite (not a Levellite as you stated. Mine also say Hi Power 3000----so is yours a levellite or a Levelrite.
Old 09-26-2011, 08:52 AM   #14
dkottum's Avatar
2012 25' Flying Cloud
Battle Lake , Minnesota
Could be low voltage output of the battery; maybe something was left on overnight. Be sure the battery is fully charged.
doug k
Interesting Tongue Jack electrical problem Wingeezer Jacks, Stabilizers, Lifting and Leveling 15 10-12-2012 10:08 PM
Jack & Lug nut wrench Tim_S Tires 41 10-31-2011 08:27 AM
Hitch age? Skater Hitches, Couplers & Balls 18 09-03-2011 01:12 PM
Barker Super Jack Problem Luckyducks Jacks, Stabilizers, Lifting and Leveling 1 03-20-2011 08:49 AM
