Old 02-22-2011, 01:33 PM   #1
2010 30' Flying Cloud
Canyon Lake , Texas
Need Tongue Jack - Suggestions?
Ladies/Gents:
My AS has no tongue jack. There is still some hardware on the tongue, but I don't know how it relates. (Picture below) There is some sort of ball below the propane tank bracket as well as another contraption to the left of the ball.
1. Do y'all know what these gadgets are?
2. Given what I have now, do any of you have any suggestions?
3. I am inclined to find a manual jack because it seems the electric jacks are problematic.
Thanks.
KJ
kj78133 is offline   Reply With Quote
Old 02-22-2011, 01:39 PM   #2
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
The circular(racetrack) bracket is for propane bottles. The rear most bracket is for the weight distrubution hitch(should be one on the other side of the tongue also. The little ball is for a friction swaybar. U didnt show far enough forward to show what the end of the A frame looks like. The jack would be located right behind the coupler.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 02-22-2011, 02:10 PM   #3
Canyon Lake , Texas
Thanks for the quick reply; I never would have guessed what those two things were used for. Looks like I need a jack with an "A" frame bracket.
KJ
ID:	122876   Click image for larger version
Old 02-22-2011, 02:54 PM   #4
Splitrock's Avatar
Sioux Falls , South Dakota
My electric jack is OEM vintage and it works fine, but I'm planning to replace it with a manual jack. I have manual jacks on my other two tandem trailers and they work every time, summer, winter, without electricity. It's . . . would I rather have a jack that's easy or one that works all the time?
Old 02-22-2011, 03:36 PM   #5
Gainesville , Florida
The jack goes in the round hole just behind the coupler. I prefer a manual jack. zz
Old 02-22-2011, 04:53 PM   #6
Excella CM's Avatar
1978 31' Excella 500
Venice , California
An electric jack saves time and effort. When you are setting the weight distribution bars, using the jack to flex them makes it a lot easier to close the latches.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 02-22-2011, 06:28 PM   #7
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
I don't know that electric jacks are especially "problematic" and they're not terribly expensive. But my manual jack does work every time ... so long as not too much beer gets into the "motor" !!??
I keep thinking about installing an electric lifter, but somehow I just don't. It's true that electric "saves time and effort." But not too much of either one. Maybe after this season. Or the next.
AirsDream is offline   Reply With Quote
Old 02-22-2011, 06:57 PM   #8
elbundi's Avatar
2005 25' International CCD
Leesburg , Georgia
You can buy an electric jack that has a manual handle. Best of both worlds
elbundi is offline   Reply With Quote
Old 02-22-2011, 07:17 PM   #9
Moderator dude
Action's Avatar
1966 26' Overlander
Phoenix , Arizona
Images: 13
I have an electric jack on my '66. It is original equipment and it is still working. I am actually surprised it is still working. It would be a drop in replacement for that hole.
>>>>>>>>>>>>Action
Old 02-22-2011, 07:22 PM   #10
Jim Foster's Avatar
1965 17' Caravel
1983 27' Excella
Electric.
Push the button!
Past President, El Camino Real Unit WBCCI#6620
Street Rod Builder (see avatar)
Kite flier (check out links below)
http://www.youtube.com/my_videos?feature=mhee
https://www.youtube.com/watch?v=6y1_U2XQ0bI
Old 02-22-2011, 09:49 PM   #11
Mexray's Avatar
1978 28' Ambassador
Morada , California
Here you go...Such a deal! Go electric - believe me it's well worth the additional purchase price...
Low Priced RV Parts, RV Accessories RV Supplies
Ray & Pat; Morada, CA
Old 02-22-2011, 10:31 PM   #12
Maniacal Engineer
barts's Avatar
Menlo Park , California
Our Tradewind had a small emergency handle; the motor had long disappeared. I replaced the original with a new heavy duty manual jack... it works just fine, and doesn't take a lot of effort to raise or lower.
I find it useful to feel what's going on w/ the amount of force I'm applying to the jack; if the coupler hangs up on the ball I know it right away.
As with many things aluminum, to each his or her own.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 02-23-2011, 05:39 AM   #13
grannyred's Avatar
1959 22' Flying Cloud
Bowden , West Virginia
I have a manual jack from a 2004 Bambi that I will give you. Come and get it. I live in Georgetown.
Ken
grannyred is offline   Reply With Quote
Old 02-23-2011, 02:14 PM   #14
Wheels Itch)(Must Travel
az-streamer's Avatar
2014 25' FB Flying Cloud
- east coastal area - , Florida
Images: 20
either manual or electric [i'd go electric] - i recommend that you also use a waterproof cover whenever you aren't travelling.
it will keep the manual jack from rusting or the electric jack from cr#pping out
on you when you really need it.
all the new electric jacks come with manual handles
and the install is a quick 'n easy 3-bolt job; i did mine in under 1/2 hour.
i didn't see the electric connector on your AS but i assume there is one.
az-streamer
Jon & Deb
Phoebe & Ellis - Airstreaming Mini-Schauzers
FCU WBCCI #1601
I Donít Always Pull A Trailer
But When I Do - I Pull An Airstream
Keep Moving My Friends
az-streamer is offline   Reply With Quote
1972 sovereign, 31', tongue jack
Jack Digital Over-the-Air Antenna Tallytown Audio, Video & TV 21 02-17-2013 11:19 AM
OK to use a jack instead of blocks to level? KYAirstream Jacks, Stabilizers, Lifting and Leveling 27 09-18-2012 06:42 AM
any suggestions on making bread or rice in an Airstream? aname4me Stella's Kitchen 57 01-31-2011 10:08 AM
Bear Lake, Ut Campground Suggestions NicheVintage On The Road... 6 01-17-2011 07:56 PM
Campsite Suggestions for Crescent City? ddstech On The Road... 5 01-05-2011 01:13 PM
