Old 02-23-2011, 02:55 PM   #15
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
After looking at the pictures It appears the lift bracket on the left side of the tongue is already gone. They come in pairs usually.U will get new ones with a new hitch setup. It looks like there is a spare rack under the front also. Someone took the jack.you can buy either electric or Manual. Look around for the wiring. Id put in a manual myself .Ours has a manual,but came with electric and the PO replaced it cause it didnt work. Then after having the trailer a yr I found out why. DEAD CIRCUIT BREAKER. OH well my manual works just fine.When I can't crank it anymore,I will either get electric one or sell da traylor.
Roger & MaryLou
___________________
F350 CREWCAB SW LONG BED
7.3 liter Power Stroke Diesel
1977 27ft OVERLANDER
KA8LMQ
AIR # 22336 TAC- OH-7
May your roads be straight and smooth and may you always have a tailwind!
Mikethefixit is offline   Reply With Quote
Old 02-23-2011, 04:57 PM   #16
FL Crackers's Avatar
2012 27' FB International
Ft Myers , Florida
My electric seems to be having issues. Last few times I've used it, I have had to tap (read: slap) the casing once or twice to get it to kick in. Seems that there is a dead spot (reminiscent of an old car starter) that just needs to be nudged a bit to get contact. I've attempted to pull the cover but the short wiring doesn't allow great access. Anyone recognize my problem? Is there a fix? I have no manual crank so I plan to keep a jack handy from now on in case the slapping stops working.
Mike & Laurel
Ft. Myers, FL
2012 27FB Int'l Serenity
2016 RAM 2500
FL Crackers is offline   Reply With Quote
Old 02-23-2011, 05:55 PM   #17
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I had the exact same issue on my 75 and the slapping and beating on the motor was getting worse. I pulled the unit apart and found that the brushes for the motor were worn down to nothing. The armature was also scored badly. I replaced the jack.
Richard
1972 sovereign, 31', tongue jack
Jack Digital Over-the-Air Antenna Tallytown Audio, Video & TV 21 02-17-2013 11:19 AM
OK to use a jack instead of blocks to level? KYAirstream Jacks, Stabilizers, Lifting and Leveling 27 09-18-2012 06:42 AM
any suggestions on making bread or rice in an Airstream? aname4me Stella's Kitchen 57 01-31-2011 10:08 AM
Bear Lake, Ut Campground Suggestions NicheVintage On The Road... 6 01-17-2011 07:56 PM
Campsite Suggestions for Crescent City? ddstech On The Road... 5 01-05-2011 01:13 PM
